Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Error Codes My washer has an F-01 error code the manual says push the Pause button twice to reset, but the the machine will only allow it to be pushed once. I have unplugged it and flipped the breaker off and on to no avail. I do not want to wait 2 weeks for a tech to come out.
    Scholar:
  • 93 Answers
This error is an EEPROM communication failure of the electronic control board .Basically indicates the washer no longer thinks any more as washer.
Repair requires the board to be replaced. ..But be careful so that you get the right control board.
Posted on Jul 24, 2008
Maytag epic Z He washer ecu reset
Unplug it from the wall for 5 min's to reset.
May 05, 2017 | Washing Machines
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
I have a front load kenmore washing machine and keep getting a F-11 error message, what do I do? I do as the manual said and push pause/cancel twice and sometimes it will let me restart and sometimes not.
fll error code is a communication error between (ccu) central control unit board and the (mcu) motor control unit bottom control board .... replace control board on the top of machine
Jan 23, 2011 | Kenmore Elite 45986 Front Load Washer
Error Message
Your owner's manual may give a troubleshooting guide for the error code your machine might give you. Is it possible you have locked out the control panel? I "think" the calypso has a control lockout, usually a start button or cancel button. If you press it in for 3-5 seconds, it can lock or unlock panel. If all else fails, try unplugging it and see it it will drain out the water.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error Message
what is the error message ?
machne can lock on to mush soap
May 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
F 26 Code that won't go away
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Dec 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Beeping
Thanks for posting this solution! I'll try it with mine.
Oct 24, 2007 | Bosch WFK 2401
Error codes
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Jul 07, 2007 | Kenmore 46462 Front Load Washer
Electrical problem
Teecee, F11 is a communication error between the main board and the motor control board. The main board is on top and the motor control board is behind the lower panel. Sometimes the harness to these boards become loose causing this error. You would have to get at them and reseat the connections. F dl has to do with the door lock mechanism. You might of just had the door open when you reset the machine. To get at the main board on top you have to remove the 3 screws in back for the top. It will then slide back and off. To get at the motor control board, you will have to remove the bottom panel. The board will be in the back. Catriver..post back.
Oct 25, 2006 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
322 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
