MY SONY LAPTOP WONT BOOT
MY SONY LAPTOP TURNS ON, I SEE A GREEN LIGHT AND, A FLASHING AMBER LIGHT, IN FRONT OF THE SYSTEM, BUT, THE SCREEN STAYS BLACK, AND, I HEAR NO NOISE, AT ALL, COMING FROM THE SYSTEM?
  • huang_168 Nov 12, 2008
    I have same problem, but if I keep the laptop power on and wait some minutes, then power off and power on again, the laptop will get back to the normal. looks like the laptop now need a waming time. anyone help?
  • Madhav Suresh May 11, 2010
    Try shining a flash light up to the screen, can you see anything?
    Guru:
  • 859 Answers
The flashing amber light means the screen is in power save mode. Since you are not seeing a "No Video Signal" things are looking up.
You want to use the menu buttons on your screen to navigate through and locate the power save time out settings. Its best to set it for 'never'.
If that makes the change a fix, let me know, I'll guide you through the settings on your desktop display to control the display time out.
Regards,
Worldvet
Posted on Jul 28, 2008
Wont Boot 1st PSU Flashing Amber
standard troubleshooting:
1) I've seen power sources appear to power up a system, but are somehow broken just enough to not get the system to POST (do you have another system you could at least borrow the power source from?)
2) pull anything you can so that you just have mobo, power, cpu, memory, and graphics.
2a) try using just one memory chip (and try each chip you have, or best to borrow a chip from a working system); even try different slots
2b) if onboard graphics, try a known working graphics card addon
2c) does the screen power off (like normal sleep) or system shutdown? if latter, try re-thermal pasting the heat sink to the cpu.
May 22, 2016 | Fujitsu Siemens Siemens PRIMERGY RX300...
Amber light on then a while turns green but wont boot
1) Switch the system on. Can you tell me if the power button is flashing amber or a solid amber? Please also tell me if you notice any diagnostics LEDs staying lit - these are labelled 1,2,3 and 4 and are near the front headphone sockets
2) Please remove all peripherals at the back of the system and switch the system on. Does this affect the power button LED or diagnostic LEDs
3) Have you added any components to the system e.g. video cards, sound cards etc...
4) Please open the system and remove the following components:
a) Power and data cables from hard drives and optical drivesb) Any PCI/PCI-Express expansion cardsc) All memory from the systemd) The system fan
5) With the above removed, please reconnect the power cord to the back of the system and switch the system on. Please make a note of what happens with the power button LED and the diagnostic LEDs
6) If there are no changes to the power button LED or diagnostic LEDs, please remove the power cord from the back of the system and remove the following components:
a) I/O panel cableb) CMOS battery
7) With the I/O panel cable and CMOS battery removed, please connect the power cord to the back of the system. The system should automatically try to switch on. Do you hear any beeps from the system? If so, can you tell us exactly what you hear?
If you need any assistance with removing these components, please see the User Manual here: http://support.euro.dell.com/support/edocs/systems/op380/en/index.htm
Please keep us updated on how you get on!
May 21, 2014 | Dell OptiPlex 380 MT Desktop Computer...
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
I turned my ps3 on today and the light turned green, then amber and red and the system beeps three times. the red light then just keeps flashing. When i tap it while its blinking it stops but when i do...
i have the same problem but to make matters worse mine wont even turn on now but a bunch of people say you have to take it to sony or i dont know if this works but a bunch of people say is does try turning it on or off (i dont know which one) and press the eject and front power button at the same time hope this works tell me if it does
May 07, 2010 | Sony Playstation 3 (PS3) Console
Screen will not come on hard drive light no light checked power supply is ok
Things to check:
  1. Power led on the front of the tower, it should be solid green when on. Flashing Amber is generally an indication of a bad power supply inside the tower
  2. Power LED Solid AMBER indicates system is not finishing the power on self test (POST) and you remove all connections from the tower except power and try turning on again. If no change, remove all PCI and PCI-E cards from system, try again, no change replace motherboard.
  3. On the back of the tower are 4 diagnostic LEDs near the ps2 ports marked ABCD, after the POST, during a normal boot the will flash in several sequences and with boot is finished all 4 should be green. If they stop an a different pattern, then that indicates a failure Yellow Yellow Green Green indicate bad RAM for example
  4. If the LEDs on front and back are Green then the system appears to be booting but the monitor display is not functional
Feb 05, 2010 | Dell Dimension 4600 PC Desktop
Flashing amber light
Attempt to boot the laptop with the battery removed and the AC plugged in. IF this boots ok it may very well be the battery circuitry which has failed.
Nov 26, 2008 | Acer Aspire 5315 Notebook
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Laptop crashes shortly after boot, power light rapidly blinks red.
Its late, so just to make sure I'm not brain-dead basically your laptop runs fine as long as its powered by the AC adaptor but dies fairly quickly while running via battery. This is very typical of a battery that will no longer hold a charge, not normally a user repairable item. It could also be that the charging electronics (in the laptop) isn't charging the battery, again not a typical user repair job. About your only option short of taking it to the repair shop is buying or borrowing a battery as a test.
Dec 12, 2006 | Medion (40010998)
Computers & Internet Logo
276 people viewed this question
David Payne
David Payne
