Question about Panasonic Panafax UF-780 Plain Paper Laser Fax
Panafax uf 780
When fax is turned on it initializes. then display flashes "toner is running low order new cartridge.then it flashes "no cartridge info code=045. it has a new toner cartridge and the toner sensor has been replaced. any suggestions what it could be.
  • snapper 1 Jul 25, 2008
    yes the toner cartridge is oem.
  • jon_than21
    jon_than21 May 11, 2010
    is your toner genuine?
    Genius:
  • 2,120 Answers
Make sure you have not installed a Toner Cartridge made for the Panafax 585/595 or one for a Kyocera-Mita KM-F650.or Pitney Bowes
It should be UG-5510
The all look identical.
Posted on Feb 06, 2009
ERROR CODE 041 ON PANAFAX
There is a fix for this. But only a Panasonic tech has access to the parts for the fix. The toner sensor underneath must be moved closer to the cartridge, you are not low on toner.
Jun 15, 2010 | Panasonic Panafax UF-790 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
scroll down to SHIPMENT SET
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-788 Error Codes...
You have a bad laser unit, no parts are available anymore.
Nov 20, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Panasonic copier/fax UF 885
It sounds like you are stuck in the boot-up mode.
Try this:
Open the toner door and remove the cartridge
Turn the machine off
Open the document feeder by pulling straight up
While turning the machine back on, hold down the pointed switch actuator closest to the small glass
Close the document feeder..display should read "RAM INITIALIZE"
Scroll down to "SHIPMENT SET"
Press "SET"
Press "2" for "NO"
Wait for the machine to reboot (could take 5 mins)
Some times a bad toner cartridge will cause this.
If this does not work, you have a bad Main PC Board. Uneconomical to repair.
Sep 19, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-7100 showing install developer
Unplug power / plug back in.... NoGo? try this:
Function
7
press monitor key slowly 4 times
6 (RAM INITIALIZE)
scroll down to CLEAR FLASH MEMORY
set (wait for reboot)
If that doesn't work, scroll down to ALL JOB CLEAR and set.
Last resort....
set
2 for no
Did the developer problem go away?
Sep 08, 2008 | Panasonic PanaFax UF-8000 Laser Fax
PanaFax UF-780 toner error.
If you mean a 788, there are moveable tabs on the front top of the cartridge that trip switches. Move them around.
Several companies have their own brand names on Panafax's. Their toner won't work. Kyocera must be kyocera Toner, Canon must be Canon toner, etc.
Aug 05, 2008 | Office Equipment & Supplies
Drum Cartridge
The drum and toner are all in one cartridge on that product.
You can shake it and see if that will help. But even at that its low and will need replaced soon. Price looks to be about $66.
Mar 25, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic Panafax UF-780 Plain Paper Laser Fax Logo
238 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
