TECHNICAL PRO 2000S Z POD RECEIVER
I HAVE HAD THE AMP IN AUSTRALIA FOR A WEEK .THE UNITS FUNCTIONS ALL WORK,BUT NO SOUND FROM AMPLIFIER
    Genius:
  • 1,847 Answers
Has this ever worked, was dead out of box.
Posted on Jul 24, 2008
  • Legin Varghese
    Legin Varghese Jul 24, 2008
    Check the manual to make sure you are using the proper AUX.
Can i hook a amplifier to my technics receiver model no sa-ax720
If the Amplifier has more Output Power and Better Quality Sound then it is worthwhile to do so -Yes you can connect Amp to Technics Receiver you have mentioned
Jun 24, 2015 | Technics Audio Players & Recorders
I bought a technical pro z pod 2000s from america and can get no sound from it.all functions work except the sound from amlifier.i live in Australia and have changed voltage to 230v and put international...
First thing would be to check for a blown fuse. Have you ever opened up the amp? Has any maintenance or repair been done? Hopefully you'll get by with replacing the fuse. Hope that helps..........
Jul 24, 2008 | Audio Players & Recorders
Connect a TV to a Tehnical Pro AMP 1100
Depends if your TV has audio outputs. If not use the Headphone Out, just get an adapter cable from that to the amp.
Luck.
May 24, 2015 | Technical Pro LZ-1100 Amplifier
Svi 3204
From your question, I don't know if you're looking for an amp board, or preamp board. These two functions may be covered by multiple boards.In any case, they are no longer available. Your unit would need to be troubleshot by a competent audio tech to the component level. If you need more assistance, or would like to inquire about a repair, please visit my website, audioserviceclinic.com. Thank you.
Jun 15, 2014 | Technics Audio Players & Recorders
I have got the technics SH-EH550 UNIT, but i want to utilise the suround sound functions of the SH-EH750 unit on my system. is it just a case of unplug the EH550 unit and replace that with the EH750 unit...
As you stated technics SH-EH550 UNIT can be replaced with SH-EH750 unit ,
Since this unit has the main power Amplifier with suround sound functions in it,you do not need the other units unless you do not plan to use..
Hope this helps!..if more help requires pls let me know.
Jul 07, 2011 | Audio Players & Recorders
RCA inputs not working on LZ-1100
Push the input souce select buttons on the front of th unit to select the proper input.
Twist the jacks into the amp to remove any corrosion on the terminals or the cables.
Good luck
Jun 21, 2011 | Technical Pro LZ-1100 Amplifier
Does my turntable need a new cartridge? I have a Technics SL DD22 which hasn't been used in a while. I hooked it up to a Bose receiver which works fine (hooked up an i pod to it before) & it plays...
The output from any regular turntable is far too low for most amplifiers to handle. You need to either run the output through a pre-amplifier first to bring the signal up to line output levels suitable for most recording devices and amplifiers or run it into an integrated amplifier which includes the pre-amp stage.
If your Bose receiver specifically includes a turntable input then it has a pre-amp built in, but as so few folks use turntables any more very few devices have the correct input. Pre-amps are still easy to obtain and can be very cheap, but cheap ones produce a noisy and unpleasant output which is magnified by the amplifier. If ever there's a choice to be made, spend the money on the pre-amp and go budget on the main amp.
I hope that I've saved you wasting money on something you didn't need. Please take a moment to rate my free answer.
Sep 24, 2010 | American Audio Vinyl 101 Direct-Drive...
My Line 6 Spider Amp sound goes out when I plug in my FBV express pedal. Any advice?
Read this cut and paste and verify compatibility as a first step:
*FBV is not compatible with Spider II 15 or Spider III 15.
**FBV is only compatible with POD 2.0 units with pedal jacks labelled "FBV Pedal." It is not compatible with older units which have pedal jacks labelled simply "Pedal."
(NOTE: FBV is NOT compatible with Ax212, Flextone I, II or HD, POD® Pro, Bass POD®, Bass POD® Pro and Spider.)
Note there are apparently several versions. Check compatibility at this site:
http://line6.com/footcontrollers/fbv.html
May 07, 2010 | Line 6 Spider Iii 120 Stereo Guitar Combo...
How do i cnnect an ipod to a bose am plus 100 business amplifier. we have one at my job but their are no standard inputs
Does your bose amp. has an headphone input?
If it those,get a jack head that has a small like the size of your i pod head phone space.(small jack to jack cable).
Connect one of the jack heads to your i pod and the other to your amp.
Check if your amp. as any of this functions it,(aux,tunes,phone,video).
click on any of their functions.
But make sure your speakers are connected properly to your amp. try it out it will work.see yah
Jan 18, 2010 | Audio Players & Recorders
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
27 people viewed this question
 Grubhead
Grubhead
