Question about SmartDisk PhotoBank PB40 40 GB USB 2.0 Hard Drive
My device couldn't turne on
My device couldn't turn on when I use USB or A/C power but I did see the LED light on. It was red signal though. Even I charged the device for 3 hrs, the LED wouldn't turn green. I have pictures inside. What could be the problem and how could I recover the data?
Thanks
  • Anonymous Aug 21, 2008
    I have the smartdisk photobank pb40 and it won't mount on any computer. I've tried different cables too. Nothing. The LED light stays red even after being charged for 3 hours. I hear the disk spinning but nothing happens. I need to retrieve some data from it. Does anyone
  • crumble68 Dec 06, 2008
    I have exactly the same problem.
    Problem Solver:
  • 19 Answers
I had this problem but I let it charge on ac overnight and then it worked again, however the battery is shot and will only hold a short charge.
Two solutions for these devices if they wont turn on.
Solution one would be to open it up and replace the battery.
Solution two is to remove the hard drive from inside and hook it up to a computer to remove the data. Or you could also take the device to a drive recovery company and have them do it.
The drive inside is an ordinary Toshiba Laptop drive. You can buy an adapter to hook these to a usb port from many online stores. Cables to go has one here http://www.cablestogo.com/product.asp?cat_id=1541&sku=39994 There may be cheaper ones on the market or you may call a local computer repair shop and they may be able to do this for you. As they are using standard drives the data should be safe and on the drive.
Posted on May 15, 2009
Kindle won't turn non
Try these:
Reset the Kindle
Hold down the power button, or hold the power slider to the right, for at least 20 seconds. Then release the power button or switch, and push it again to turn on the device. If that doesn't work, hold the power button or slider for up to a minute, then release it and try to turn on the device.
Is there a power issue?
When you plug your charger into the Kindle, the LED should turn yellow if the device is charging and green when the device is fully charged. If the light doesn't turn on at all, it definitely signals some kind of power issue. Replace the charging cord if possible.
The Kindle uses a micro-USB connector, the same as most mobile phones. Try changing the cord or if that doesn't help, try another power source - a different charger, or connect it to a USB port on your computer. Finally, gently wriggle the adapter where it enters the Kindle. If the charging port has come loose, this movement may cause the port to realign and the LED to illuminate.
Aug 04, 2014 | Amazon Kindle Wireless Reading Device
Reprogram the remote,how?
1. Turn on the device that you want to set.
2. Aim the remote control at the device and press down and hold CODE SEARCH button for at least 3 seconds until the red LED lights up solid red.
3. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the LED light will blink once and then remain solid red.
4. Using the number keys, enter the 3-digit code. After you have entered the 3rd digit, the red LED will turn off indicating that the code was recognized for the device.
(NOTE: If the code entered was not compatible, the red LED will flash several times. You will then need to repeat Step 2. You have 30 seconds to enter a code.)
5. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying to program powers off, then you have found the correct code. If the device does not power off, then you will need to repeat the process again from Step 2, using another 3-digit code.
The manual can be found at jumboremotecontrol.com
http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Apr 06, 2014 | Innovage Jumbo Remote Control
Turn signal lights don't work even though hazards do
Sound like a flasher device go to bad; check in fuse box and replace it to solve this problem.
Jun 11, 2012 | 2006 Chrysler Town & Country
Put led indicators on my yzf1000r thunderace i changed the flasher to an led flasher so it has the correct flash rate but now all the indicators flash at same time ???
Hi, Joshcunningh before testing any electrical component in the Light Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries, also before diagnosing any turn signal/running light/parking light issue make sure the bulb is good and the light fuse has continuity with a test light. If you have replaced your OEM lights with one or all LED lights you are going to need a load equalizer.
If no turn signals work the cause could be a faulty turn signal module or the connector going to it, look for corroded, loose, or broken pins/sockets. Contact spray cleaner is great for removing corrosion.
If all four turn signals flash at the same time like hazard lights even though you only pressed one turn signal button then you have a LED light in the circuit and need a load equalizer that can be purchased from any motorcycle parts supplier.
If your speedometer does not function properly it will have to be fixed first because your turn signal module gets the data from the speedometer for normal turn signal function.
If your front turn signals don't work use a test light to check for power and ground at the bulb socket, then start backtracking the wiring through every wire connector to the turn signal switch/button and check for continuity, go all the way back to the fuse if necessary to find the cause of the malfunction.
If your rear turn signals don't work check your rear fender wiring harness connector first for corroded, broken, loose pins/sockets, power, and a good ground, the harness connector is usually located under the seat on the front of the rear fender then keep tracing the wiring look for obvious harness damage caused by the rear tire.
If you still can't find the malfunction backtrack from the rear fender wiring harness connector.
If one side does not work you could have a faulty turn signal switch or module check for continuity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
led signals all flashing at once XJRider com
All 4 turn signals flashing at the same time Suzuki GSX Motorcycle Forums...
Yamaha YZF1000RJ Service Manual
OEM parts for Yamaha
Yamaha YZFR1X Owner Manual
Jul 05, 2011 | Yamaha YZF Thunder ace 1000 R Motorcycles
My transcend 320GB harddisk has all my important data. Few wks back, I connected it to the laptop, and it showed some of the folders as "do u want to format" even though these folders had data in...
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Apr 25, 2011 | Transcend StoreJet 320 GB USB 20 Hard...
I NEED T.V CODES FOR A ADMIRAL T.V AND NEED STEPS ON HOW TO SET UP CODE FOR A INNOVAGE REMOTE
Hello
Code for Admiral TV with Innovage remote control are:
001,173
CODE INPUT SETTING:
You will need the list of codes to manually select and input the correct codes to your
specific device.
2. Look for the brand name under the specific device listing provided.
3. Aim the remote control at the device and press down and hold CODE SEARCH button for
4. Press the device button for the item you wish to program, e.g. TV, DVD, VCR, etc. and the
5. Using the number keys, enter the 1 st set of 3-digit codes from the list. You will notice
that each number that you press, the LED will blink once. After you have entered the
You will then need to repeat Step 3. You have 30 seconds to enter a code.)
6. After the red LED light has turned off. Press the ON/OFF key. If the device you are trying
power off, then you will need to repeat the process again from Step 3, using another
3-digit code.
7. Make a note of the 3-digit code for future use.
CODE SEARCH SETTING:
This is an alternative method to programming your device without using the code list. The
remote control will scroll through the list of codes to identify the correct code for your
device.
2. Aim the remote control at the device and press and hold down the CODE SEARCH button
4. Press ON/OFF button on remote slowly and repeatedly until the device you are trying to
program shuts off. (Note LED will blink once each time you press ON/OFF button)
5. Once this occurs, press ENTER button to store the code and the LED light will turn off
Mar 27, 2011 | Innovage Jumbo Remote Control
So i have a Toshiba 1 tb external hdd(px1396e-3t01) for almost 8 months now. It worked perfectly until yesterday evening. I was watching southpark from it and suddenly the led which supposed to light blue...
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Sep 18, 2009 | Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB...
Yesterday, when driving, I noticed that the device said i was receiving no signal, even though I was out on the interstate... I got frustrated and turned it off... I figured that it would give it ample...
The green light does not necessarily mean there is power to the unit or charging the battery. If the unit is more than 3-5 years old, you may have success with replacing the battery. If you have a power source with sufficient current output capabilities then you could try that with the battery removed.
Jun 16, 2009 | Tomtom GO 910 GPS Receiver
Power light on& status light on
The power red led indicates that your device is "power on" , but the status led still red and turn to green if the device ( video input )received video signal ( from DVD player, Laptop etc. ) .
Apr 29, 2009 | Computers & Internet
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
SmartDisk PhotoBank PB40 40 GB USB 2.0 Hard Drive Logo
410 people viewed this question
Top SmartDisk Computers & Internet Experts
Brian Sullivan
Brian Sullivan
sonic boom...
sonic boom...
Clive Gray
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
