Samsung HT-X20 Home Cinema 600W Theater System Logo
Posted on Feb 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Play only 10 seconds on USB ......region code , register ... ?! romania region 2.
Muntejaya Ginting
Level 3:
  • Master 10,422 Answers
  • Posted on Feb 27, 2011
Muntejaya Ginting
Master
Level 3:
Answers
10422
Questions
Helped
2468512
Points
19564
How to unlock denon bluray dbt1713ud?
You can use a USB stick for region A, B or C. (1, 2 of 4)
On the USB stick there is one file named autoscript with the following : CLI(CLI_app.homemenu.set_bdreg 4). ,4 you can also use 1 or 2 this depends on the disired region.
Just copy this with textprogram and name the file 'autoscript'
T
1. Remove any discs from the drive of your player
2. Put the player into standby
3. Put the USB stick with the desired bluray region into the player
4. Turn on the player
5. Wait 5 seconds
6. Put the player into standby
7. Wait 10 seconds
8. Remove the USB stick
9. Unplug the mains cable
10. Unit should now be the region you have chosen for bluray
Before you do any firmware update, return to Region B as it may lock the region.hen do the following:
Code multiregion
here is one way:
To change the player region code
1. Be sure players drive is empty (nodISC)
2. Enter following key sequence using remote control:
Enter, 6, >=10, <<, 00F2, Audio, 8, * requested region code here (1-8) *, Subtitle, 1
3. Player will reset and requested region code will be set.
- For example to set region code to 3 press: "Enter, 6, >=10, <<, 00F2, Audio, 8, 3, Subtitle, 1"
To set the player to RCE proof region free
Enter, 6, >=10, <<, 00F2, Audio, 8, 1, Subtitle, 4
3. Player will reset and set to "region-free" and "RCE-free" mode
To restore players factory region code
Enter, 6, >=10, <<, 00F2, Audio, 8, 9, Subtitle, 1
3. Player will reset and set to factory region code
and here is a forum whre you can get more information
http://www.avforums.com/forums/showthread.php?s=df1223ea6de85d218b01e9719ddec248&t=368649
tip
Region free code for Samsung DVD M105
Code 1:
Switch the player off and on.
Hold the play and stop buttons (for 10 seconds).
Press the Repeat button on your remote control.
Using your remote control enter the code below (note that you must know what Region your player is currently set to in order to know which code is appropriate):
For Region 1 use 2, 9, 3, 3 and 4;
For Region 2 use 3, 8, 7, 6 and 7;
For Region 3 use 5, 6, 7, 3 and 2;
For Region 4 use 7, 6, 8, 8 and 4;
For Region 5 use 5, 3, 8, 1 and 4;
For Region 6 use 2, 4, 4, 6 and 2;
A code should be displayed on the screen indicating the current Region setting of your unit.
Press the 9 button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on.
Press the Open button on your player.
Press the Standby button on your remote control.
Code 2:
Power on.
Press the open/close button, the CD-tray will come out, remove DVD or other CD if present.
Press REPEAT button once.
Enter following numbers: 38767.
Yyou will then see '02' on the TV-Screen.
Press button number: 9.
Press the open/close button.
Power off, then on.
on Mar 07, 2010 • Televison & Video
tip
Region free code for Samsung DVD M103
Code 1:
Code 2:
Power on.
Power off, then on.
Would like unlock code to play regions 1-6 on my panasonic sc-bt207
Please follow the steps : To change the player region code
Regards, Jay__g6
2answers
Panasonic dvd-s54 unlock code to make it play region-free
Regards, Jay__uji8
2answers
Region 1 DVDs will not play on my recently purchased panasonic blu ray. is there any input code to allow play
Regards, Jay__okp9
What type of format i can play with my Sony Play Station 2, Model No: SCPH-75004, Can i also play audio songs through pendrive with help of USB in Sony Play station 2
No on the usb also cant you just play audio cds on the ps2 unit it's self and for format a us region ps2 can play DVD, CD,blue disc and black discs with region code ntsc u/c
2answers
No more region free
if you got the code its not a hack cause these codes are given out to those that request them when a person moves out of country its easy to change region just contact local provider of the devices you want to change regions they will give you the codes for regions
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
