Question about LG DU-52SZ61D TV
LG DU-52SZ61D you gave advice on
I'm new to this site so i hope I'm doing this properly. I posted a response to what you wrote yesterday, and it showed up as a comment. Now I noticed the ask me button. I apologize if this is not how I should do this.
Anyway, after checking the things you suggested yesterday, I can stand by the guesses I made in my comment. The color wheel is fine, the light is probably bright enough, but even if it wasn't wouldn't account for the brighter strip on the right side I imagine.
I looked further into the chassis of the set last night and I have to say whoever worked on this set was either lazy, incompetent, or both. Every screw holding the cassis down and the power supply board to the chassis was gone except for one - a large headed, small shafted bolt holding the chassis to the base of the case. It appears there should be at least one more of these large bolts, in addition to several coarse thread screws holding the various sub components together. Still, the various components were in the right place, as there are dowel pins and guide that ensure correct alignment. These were the only things keeping the guts from flopping around the set.
This leads me even further to believe the problem is some sort of obstruction or misalignment in the optical path. I suspect when the light engine originally went bad, it was not repaired under warranty by a technician as the previous owner claimed, but rather he tried todo it himself and badly botched the job. He said it worked fine after, until it was bumped, but it's entirely possible it never worked right after the "repair". At least it seems he got the engine installed right electrically, since the set does work and has the visible but dim picture as stated.
I plan to pull the chassis out, look for problems then replace it correctly with new screws. I need a service manual to reliably do this however. servicemanuals.net has a downloadable manual for the RU-52SZ61D for $15.99. From what I've read the only difference between that and the DU set I have is mine has the HD tuner and cable card slot. Hopefully everything else will be the same, especially the exploded view diagram and parts list if needed. Unless of course you might know where I can get the manual specific to my set?
Do you have any tips or other information for me before I start? i really appreciate your help so far. I'm really hoping to fix this set myself as I've had several unexpected expenses lately and money is rather tight for the time being.
Thanks again, very much!
David
BTW, if you need to contact me directly, you may do so at david@NOSPAMonsitecomps.com Obviously remove the nospam part.
  • onsitecomps Jul 24, 2008
    Darn, just noticed it placed this as a new request. I'm sorry about that. i don't see any way to delete it or move it, but I imagine you'll know which posting i was referring to Shuttl.
    If the mods want to move/remove this, I understand.
    Thanks.
    David
    Genius:
  • 1,139 Answers
Hello onsitecomps,
I was working on a projection TV the other day and I am wondering if this set has filter mirrors? Filter mirrors are mirrors that filter out all colors but one and the use the combination of the colors to produce a luminance light( white light ) which is projected along with the RGB lights. This might be the problem that is occurring here if the mirror that reflects the luminance light is damaged it would still show the color picture but without luminance. This is just a thought that hit me. I'll post this to the other posting also.
I hope this is of help to you,
Thank you,
Shuttle83
Posted on Jul 25, 2008
Need power supply for du-37lz30 whair can i gat one
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 15, 2015 | LG DU-37LZ30 37 in. LCD HDTV
I want to ic la7840 circuit diagram
https://www.google.com/search?q=la7840+circuit+diagram&tbm=isch&tbo=u&source=univ&sa=X&ei=wSFuU_2lIZOdyAScqILIDw&ved=0CCgQsAQ&biw=1920&bih=1104
May 10, 2014 | LG DU-52SZ61D TV
Beckman DU 530 spectrophotometer has monochromator error code
He's not talking about a washing machine. It's a laboratory spectrophotometer posted in the wrong section.You'll have to send it for diagnosis and repairs. Our lab's 520 gave the same error. Estimated repair: $2-5000.
Feb 26, 2013 | Washing Machines
My GSA 2166D does not recognize dvds when I insert into drive, it will recognize and burn to cds is this a lens or driver issue? The program that I go though tells me that there in not a disk. I tried a...
Hi As your drive is burning cds but wont burn dvds, I suggest your try other brands of dvds and a different burning program.I use Ashampoo Burning Studio 6 FREE, which you can down load free from the web.Hope this helps you.
Regards Bill
May 15, 2010 | LG GSA-2166D DVD RW Dual Layer Burner
DU 50PX10 Need help checking volages on boards
There is one site call www.service-manual.net
The service manual you need is $11.99
This will show you all the test point and values. Plus, part numbers
I hope I answered your question. Please rate me. :)
Mar 08, 2009 | LG DU-50PX10 50 in. Plasma HDTV
Need STR number for LG DU-37LZ55 TV
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 15, 2017 | LG DU-37LZ30 37 in. LCD HDTV
62" LG Rear Proj DLP TV color wheel replacement
I just had to replace the color wheel chassis which ran $700.
Dec 29, 2008 | LG DU-52SZ61D TV
Red Stripe, right side
I have the same problem but mine is 3 years old? Im taking mine to the shop on tuesday to have it looked at .... this sucks!!!
May 01, 2008 | LG DU-42PY10 42 in. Plasma HDTV
LG DU-52SZ61D TV Logo
253 people viewed this question
Computer Repairing
Computer Repairing
