Question about Hampton Bay Heating & Cooling
Hampton Bay 54 In. Brushed Steel with Remote wont turn on and have the same on in the other room, could it be that the remote doesnt like two of the same fans in a area
  • 143 Answers
This should be posted in the FAN section.
Posted on Jul 24, 2008
Instalation diagran for windward II speed control unit
I thought this fan comes with a remote. You can't use both.
Aug 03, 2014 | Hampton Bay 54 in. Windward II Brushed...
Www gpwarranty com
for the Problem with Hampton Bay 54 in. Windward II Brushed Steel Ceiling Fan check the manual
http://lightingworldbay.com/windward-iv-52-indoor-brushed-ceiling-fan-manual/
Apr 25, 2013 | Hampton Bay 54 in. Windward II Brushed...
Do not have a remote
If this is a Hampton Bay fan, you probably can buy a suitable remote from a Hampton Bay dealer...BUT before rushing out to buy a remote, it would be a good idea to find out whether the reason this fan turned up at a yard sale is not that the remote receiver failed
Jan 07, 2013 | Hampton Bay AC418-OBB 60'' Brookedale Oil...
Hampton Bay 54 In. Brushed Steel with Remote Model 55295 just stopped working and remote works with other fan so remote is fine. where is code on fan so i can check that and rule that out
Check on top of motor, there should be a small opening with four very small (DIP style) switches.
I presume the fan is installled, so you'll need a ladder to check that, please be safe. Remove the battery cover from your remote, you'll find four similar switches there too. Combination must be the same for the fan to work. Good luck!
Jun 18, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
Unable to get fan to respond to remote Hampton Bay 54
these fans must be reset as follows remove the battery from the remote manually turn off the wall power switch put the batteries back in the remote turn on the wall power switch press the remote buttons...if this doesn't work let me know
Jun 01, 2009 | Universal Remote Control Hampton Bay...
Hampton bay 54'' fan stopped working
make sure the main switch is on ,also if there is a fan switch make sure its on before using remote
Jan 04, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Installed
The dip switches on the remote and on the fan have to match - which makes the remote and the fan on the same radio frequency so they can talk to each other. They all come with the same default setup of the dip switches (all in the "on" position and therefore they are all on the same radio frequency). That's fine unless there is a similar remote control fan nearby. So a remote might talk to several new fans if they are similar brand or same remote etc on the default dip switch settings and therefore same radio frequency. It's up to you to change the dip switches if you need to. You need to. They give you the ability to change the frequency so you don't control a similar fan down the hall, upstairs etc , while also controlling the one in the room that you intended to control ie your problem. As long as the remote and the fan match, they will talk to each other. So you have to change the dip switches on one of the remotes and the fan you are using that remote on to something different, but matching. There are usually four dip switches, usually all in the "on" position. So, for example, change the first dip switch to off on the remote and do the same to the fan - turn first dip switch off. You'll probably have to take the fan down and take off the top to get at the dip switches. That should fix the problem.
My fan: Hampton Bay 54 In. Brushed Steel with Remote Model 55295
Mar 08, 2008 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Remote Control Problem
I had this problem. One day everything worked. The next day the fan ran at 1 speed and the remote didn't turn on the light, change fan speed, nothing. I changed batteries on the remote - no good. As you should know, the dip switches on the remote and on the fan have to match - which makes the remote and the fan on the same radio frequency so they can talk to each other. (They let you change radio frequency so that you don't control a similar fan down the hall as well as the one in the room that you intended to control.) Anyway, come to find out from the fan guy at Home Depot that sometime the dip switches on the fan "fall" out of place leaving the remote unable to talk to the fan. Sounded crazy, but sure enough one of the dip switches on the fan wasn't tightly in place. Once all the dip switches were tightly in place (with the fan dip switches matching the remote dip switches) everything ran fine. To change the dip switches on my fan that meant uninstalling the fan from the ceiling and taking the big top cover off to expose the dip switches.
Dec 23, 2007 | Hampton Bay 54 In. Flemish Pewter Ceiling...
Heating & Cooling Logo
78 people viewed this question
Top Hampton Bay Heating & Cooling Experts
Tim Whalen
Pete Norton
Are you a Hampton Bay Heating and Cooling Expert? Answer questions, earn points and help others
