Question about Samsung YP-K3 MP3 Player
Yp-k3 is not being funny
Ran outta battery so i plugged it in to charge (usb) and the screen lights up reads "MTP CONNETED", me cpu recognises it the BAM! Gone nothing on cpu or Mp3 player???????
Wont charge wont turn on just keeps on doing the same old dance and its getting boring HELP ME PLEASE!!!!!!!!!!!!!!!!
When bang it on the table one time then turn it back on in like 5 minutes then it should work cuz it happened to me....
Posted on Jul 25, 2008
Player, 2 years old,(almost),love it! Now, when I
That is a common problem with Samsung MP3 players after some time, updating your firmware will fix your problem, tell me if you need anything else
Jun 20, 2009 | Samsung YP-K3 MP3 Player
NEW SAMSUNG YP-K3 DOESN'T CHARGE
The problem is with the battery or the USB cable.
Check the cable first if there is any damage replace it,if there is no damage then the problem is with the battery which is not charging get it replaced and ur problem will be solved..
If you have any other problems please feel free to ask..
Goodluck..
Feb 10, 2008 | Samsung YP-K3 MP3 Player
Tip
How to make computer identify your device
I had a problem with my YP-K3 when i lost the installation cd as my computer no longer identified the device when i plugged it in, to solve this (on windows XP) go to
1: control panel
2:add hardware
3:connect your hardware device and click "yes i have connected the hardware"
4:scroll down and select install new hardware device
5:select install hardware that i manually select from a list
6:scroll down to windows portable devices
7:and choose MTP device
this should make it so your mp3 player is now recognised by the computer
hope it works
on Aug 11, 2008 | Samsung YP-K3 MP3 Player
Samsung YP-U3 not recognised. This device cannot start. (Code 10)
  1. Connect the USB cable to your computer.
  2. Press and hold the menu[0].jpg button while plugging the other end of the USB cable into the YP-Z5.
  3. When the display shows USB Connected, release the menu[0].jpg button.
  4. The device is now in USB mode.
  5. When through, you must safely remove the USB device. Note: To safely remove the USB device, right click the USB icon ( usb_icon.jpg ) in the bottom right of your screen, and then click Safely Remove Hardware.
  1. Upon disconnecting the device, it will return to MTP Mode.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
Cannot Install Samsung MP3 Player YP - K3 on my laptop
Hmm, I read around and a few people tried to plugin the USB from the back of the computer and not the front some said it work, some said nothing.
Mar 19, 2008 | Samsung YP-K3JAB MP3 Player
Cannot chage YP-K3 player
The usb message has nothing to do with the ability of the unit to charge. It just means that the port on your computer is recognised as a USB 1.1 port.
It is more likely that the battery no longer holds a charge. The battery can be replaced but it is difficult to open up the unit without damaging the casing. There are instructions on opening up the unit on youtube. Other than buying a faulty unit with a working battery I don't know how to get hold of the batteries. Be careful when replacing the battery. If it is connected the wrong way you will fry your unit.
Feb 03, 2008 | Samsung YP-K3 MP3 Player
MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
Dec 29, 2007 | Samsung YP-K3 MP3 Player
Brand new Samsung YP-K3 charging FOREVER..
well have had my k3 die on me once, pressed reset on the back and it worked again (this in the it doing nothing anymore case) as for the cgarging thing try it on another computer, when I charge my k3 at work it charges all day but I don';t get a full battery, at home I charge it for bout 2 to 4 hours to get full battery. I think it has something to do with ho many things u have connected to ur usb ports or how much output ur computer gives to ur usb, maybe it goes to like a lower voltage to preserve electricity, no idea how to change this but unplug unneccecary things.
Dec 09, 2007 | Samsung YP-K3 MP3 Player
Device not detected!
this is so simple sir because i have same problem connect to the computer and right click to your drive and format it
Nov 15, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-K3 MP3 Player Logo
81 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
