Question about Kitchen Ranges
I have a Bonaire stove and I am trying to find a replacement griller element the model number of the unit is RAuf 600. Can someone please help me out at to where I can get a replacement element???
3 Suggested Answers
  • 2651 Answers
SOURCE: Stove element broken
cant seem to find that model number on www.whirlpool site, or for thatmatter, id check that model number again
Posted on Apr 09, 2008
  • 1456 Answers
If both gas and power supplies are on, but the stove won't heat up,the ignitors need to be replaced
Getting the right ignitor requires only the oven model and ignitor part number. Installation is quick and takes little time, even for a novice.
Turn off the gas and power supply to the Hotpoint oven. Take out any oven racks, and remove the oven's bottom pan by removing its retention screws at the oven's rear. Also take out the flame spreader by first removing the wing nut that holds it in place.
Take out the ignitor's mounting screws, and then pull out the ignitor's connecting plug--by hand. Discard the old ignitor.
Place the new ignitor in position and push into the connecting plug. Then screw into place the mounting screws.
Turn on the power and gas to the oven. Turn on the oven, and check the ignitor: if it lights in 30 seconds or less, it is working fine. Turn off the oven, and replace the flame spreader, bottom pan and any oven racks.
Posted on Nov 18, 2010
How do get rid of F10 which is on the window of my Kenmore stove
The F10 error means that the high temperature sensor is reporting a runaway temperature and shut down to avoid a potential fire. Try unplugging the stove or tripping the circuit breaker to reset the code.
If the error recurs, unplug the stove (or turn off the circuit breaker) again. Look at the broiler and bake elements with a flashlight. If it has any damage (breaks, char, melting), you will need to replace the element. Check where the elements connect to the oven and replace them if there is any charring on the back wall.
If the elements are undamaged, you need to check the wiring to identify if the problem is at the elements, the high temperature sensor, wiring or the control board. You will need to access the wiring from the back of the stove. Disconnect the wires to the heating elements. Then disconnect the wiring connections at the high temperature sensor and the control board. Without a model number, I can't be completely sure of the resistance that should be seen at various points. Please post a comment with the model number of the stove and I'll try to confirm the expected and faulty resistance values. Most likely, the resistance should be under 50 ohms but above zero between the left and right contacts of the elements and the violet wires in the wiring harness at the control board. The high temperature sensor should probably have a resistance between 1,000 and 1,200 ohms. If the resistance is high, you'll need to replace the appropriate parts. (Note: if the wiring at the control board gives a reading similar to the resistance of the high temperature sensor, the control board is the likely suspect.)
I hope this helps. If your stove is under warranty, contact Sears/Kenmore to fix the issue. If you aren't comfortable testing the wiring, contact Kenmore for a service call.
Feb 04, 2015 | Kenmore Ovens
Where are the fuses located in a frigidare stove
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Jun 07, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
What is the complete model number of your unit? Look inside the door area.
Nov 28, 2012 | Magic Chef Kitchen Ranges
What to do if one of the eyes on my stove does not work.
Hello Sajrhill, If one of your sensor eye cooking elements isn't working, you'll have to get a new replacement in order to utilize the features of your stove.
Without a brand and model number, I can't provide you with the part number for obtaining a replacement. But you can simply go to and enter in your full model number of your stove and get a complete line drawing and parts list for your stove and the correct replacement element.
Just remember to turn the power off to your stove before replacing the element. Removing the element is straightforward and only requires basis hand tools to accomplish, saving yourself the cost of a service tech and house call by doing the replacement yourself.
I hope you find this Very Helpful and best regards!
Dec 24, 2009 | Kitchen Ranges
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
BLANCO Stove Not heating up
Resolved, I took the fan cover off and the round elementjust fell apart, so I'll get a new element and all should be OK.
john S.
Jun 18, 2009 | Stoves Ovens
One element on my KitchenAid YKERS807SS00 ceramic stove top has been badly cracked and needs to be replaced, but the rest of the elements on the stove and the oven work great. Is there any way to replace...
Sure can. One element can easily be replaced. If your model number is correct, you can find replacement parts at Type in your model number in the Search menu and the surface elements can be found under the "Cooktop Parts" heading. I do not know which element you have that is bad, but they are identified as item 12 and by wattage rating. Use care when selecting to make sure you identify the correct element. The smaller elements have a lower wattage rating than the larger elements. There's also an illustrated view for easy part identification. Some parts come with directions on how to replace. If no instructions are available, or if you need further guidance, go to my profile page and click on "Tips and Tricks. I have a write up listed there on how to replace a glass cooktop. Those same instructions can be used to replace a single element. Instead of removing all the elements and cooktop, you will only have to remove and replace the one element. Just make sure you unplug the range before starting and handle the elements with extreme caution. They are considered fragile. It may also help to have a second person assist. I hope this answers some of your questions. If you need further assistance, please post back and let me know.
Apr 21, 2008 | Kitchen Ranges
Whirlpool electric stove
The ideal thing to do, would to be to replace the elements themselves. Most heating elements for stoves are universal and can be bought at lowes stores. I found your model number specific burner elements on a supply website for 42.00 each on the 8 inch and 35.95 each on the 6 inch elements. I am almost certain, you'll find these parts at lowes or home depot much cheaper. If this doesn't help, let me know, we will try another route.
Apr 15, 2008 | Ovens
Kitchen Ranges Logo
49 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
