Question about Sony PlayStation Portable (PSP) Console
Psp slim battery
My psp slim battery refuses to work ,,,in a psp slim nd psp reads that the battery is nnot inside by no indication of battery at home at top right corner and once charger is plugged out the psp turning off. pls help
  • 135 Answers
Is your battery brand new? If not, what happened and when was the last time you were able to use your battery in its full functionality?
Posted on Jul 24, 2008
PSP 2001 not recognizing battery
yes,and try using the right battery for ur system
Feb 10, 2010 | Sony PlayStation Portable (PSP) Slim...
My psp charging indicator it works but i wait an
let it charge for about 8 hours and then try it again and if that dose not work try buying a new battery
Feb 04, 2010 | Sony PlayStation Portable (PSP) Slim...
Will the psp slim battery will work for the psp phat.
Here is some advice for using the Slim-Style Pandora battery on the Phat PSP:
"Actually, I've messed with the slim Pandora in the Phat PSP's. You don't need to trim anything, just slide the head first into the battery slot and you will have to hold it in while its installing.
Also, if you are trying to use a slim Pandora battery, you will need to plug the Phat PSP into the AC adapter for it to work. The slim battery will not boot the Phat PSP on its own."
This advice is from this thread.
Sep 14, 2009 | Sony PlayStation Portable (PSP) Console
PSP can't read discs
sonds like your laser is shot, mine was too. replacement possibility i think.
Apr 03, 2009 | Sony PlayStation Portable (PSP) Console
I upgraded my psp slim to ver 5 and it cant read iso games.
U had disbled m33 updater in slim now u need to create pandora and magic stick to reflash slim
Dec 08, 2008 | Sony PlayStation Portable (PSP) Console
Psp slim 5.00m33-3 problem with psx
sounds like u have found a glitch in the 5.00 m33-3 CF
u should try to find a way to notify dark alex imediantly
if u kant then i will try
so just wait for the next CF update
Dec 04, 2008 | Sony PlayStation Portable (PSP) Slim...
Jose
Aw, ok...so, first up, to make the pandora memstick, check this thread
hxxp://www.pspmod.com/forums/psp-hardware-guides/23428-guide-making-pandoras-battery-new-method.html
just start with process 2
(Process #2: Creating the Magic Memory Stick with a bricked psp:(well, of course since your PSP is bricked))
after you've made the pandora memory stick, on to the pandora battery.
now, since your PSP isn't working and you don't have any OTHER PSP(specifically PHAT version) you'll be needing
to hard-mod your battery...how to do this? well, first you'll need a cutter, and of course your SLIM battery...the one that came with your PSP...
first up...you must open the battery...and you'll be doing this by using the cutter...carefully slice through the line at the sides of your SLIM battery...just be careful or you might mess it up inside...
then, after opening it, carefully prop out the circuit board of the battery...see this image
[IMG]http://i279.photobucket.com/albums/kk155/devileye001/enlarged.jpg[/IMG]
then still using the cutter, carefully cut the golden line (indicated by the small blue circle in the pic)...maybe 15 to20 runs of the cutter will do (that's what i did at least). Just dnt press too hard or you might cut through the whole circuit board ok? Then after cutting the gold line, you're through...just close the battery again and tape it up at the sides (i used packaging tape with mine, heheh...) and you're through with the pandora battery!
[IMG]http://i279.photobucket.com/albums/kk155/devileye001/markedforcut2.jpg[/IMG]
you'll know that you're successful making the battery when you put the battery in the PSP and the green LED light automatically turns on but there isn't any display on your PSP's screen. If it doesn't turn on automatically, just try to run a few cuts again on the line on the Batt's circuit board.
now, when you've done making youre magic memstick(or pandora memxtick) and pandora battery, just follow the steps on the link i indicated at the top where it says
"Running the files:
----------------"...and when finished, to make you're battery "normal" again, using a pencil, remember the line that you've cut before on the battery's circuit board? Just run your pencil through a few times to reconnect it and you're done. You should have your PSP running again...
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
HI PLS. HELP ME.....
HI there
some PSP consoles refuse to read isoz also check if it is set to no UMD in the recovery menu By holding L + R when turning to power on the psp ( From a hard reset )
hope to of been of help
Mike @ PSP-repairs 08
Mar 16, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
67 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
