Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
When I hit the Period Buttom it repeats the ..... multiple times ....
Everytime I hit the ..... it auto repeats ..... four or five times......
I have to delete to correct.....
Any its the only key that is doing that. Any ideas?
Thanks,
Rich
  • 781 Answers
You seem to have a stuck key try popping off the individual key pad and check for anything that will cause sticking
IE dust, foreign object, moisture, corrosion.
Posted on Jul 24, 2008
Volvo repair
Its an oil leak... DO NOT RUN THIS VEHICLE AGAIN PERIOD! Have it towed to a QUALIFIED PROFESSIONAL GARAGE/REPAIR SHOP!!!
Sep 17, 2017 | 2001 Volvo S60
Tappet clearance for 2004 honda civic vtis
2.0L only. 7 engines listed in fsm
intake= 0.0012-
exhaust= 0.0022- all below 100F.
but>>. that was just a wild guess on engine.......
no engine stated, Gen7 Civic non Hybrid?
no country stated, diffr, countries get diffr engines....!
in USA open hood, now look up, under hood see EPA sticker and Engine type stated.
lots and lots of engines, in 2004 they introduced the K- series
i-VTEC? S or SI>?
DOHC engine
here they all are. K20A" but which one? A1? Z3? what>?
http://en.wikipedia.org/wiki/Honda_K_engine
ok now ill pretend the car is USA, car.
i log in to alldata.com
i look and it has listing for 2.0L
and here is the text
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section. Disconnect the negative battery cable.
  2. Note the radio security code and the radio presets.
  3. that means record them now. pen to paper.
  4. Remove the cylinder head cover retaining bolts. Remove the cylinder head cover from the engine.
  5. Set the number one piston at TDC. The punch mark on the variable timing control (VTC) actuator and the punch mark on the exhaust camshaft sprocket should be at the top. Align the TDC marks on the VTC actuator and exhaust camshaft sprocket.
  6. Using the proper gauge feeler gauge, adjust the valves on cylinder number one.
  7. Rotate the crankshaft 180 degrees. Using the proper gauge feeler gauge, adjust the valves on cylinder number three.
  8. Rotate the crankshaft 180 degrees. Using the proper gauge feeler gauge, adjust the valves on cylinder number four.
  9. Rotate the crankshaft 180 degrees. Using the proper gauge feeler gauge, adjust the valves on cylinder number two.
  10. Install the cylinder head cover.
  11. As required, on 2001-05 vehicles, reprogram the ECM engine idle characteristics. Be sure all electrical items are OFF.
  12. Start the engine. Hold the idle speed at 3000 RPM's in neutral until the radiator fan comes on or the temperature reached 194 degrees.
  13. Let the engine idle for about five minutes with the throttle fully closed.
  14. If the radiator fan comes on during the five minutes, do not count this toward the five minute programming time.
  15. Set the clock.
  16. As required, reprogram the power window control unit as follows.
  17. Turn the ignition switch ON. Lower the window, all the way down. Open the driver's side door.
  18. Turn the ignition switch OFF. Push and hold the drivers window DOWN switch. Turn the ignition switch ON. Release the driver's window DOWN switch. This must be done within five seconds.
  19. Repeat the above step three more times. Wait one second.
  20. Confirm that the AUTO UP and AUTO DOWN do not work. If they work repeat the procedure, paying close attention to the five second time limit
  21. Move the driver's window all the way down by holding the drivers window DOWN switch to the AUTO DOWN position.
  22. Pull up and hold the driver's window UP switch to the AUTO UP position until the window reaches the fully closed position. Hold the switch for one second.
  23. Confirm that the power window master switch has been reset by using the driver's window AUTO UP and DOWN function.
  24. If the AUTO UP and DOWN feature is still not working, repeat the complete procedure, paying close attention to the five second time limit.
Dec 30, 2013 | 2004 Honda Civic
Air conditioner goes off when fan speed is increased
when it's on 'auto', the fan adjusts according to the temp in the car and the temp setting you have it set at. try setting the auto temp control down to 65, then hit the "-" one more time to send it to "LO" - the fan should automatically jump up to max.
Jul 01, 2010 | 2001 Audi A4
Airbag light flashes four or five time then pauses and repeats.
The automatic air bag sensor is tested EVERYTIME to start the car/van. Your system has detected a failure in the Air Bag deployment sensor. It is not dangerous... but the air bag with the faulty sensor will not deploy in an accident.
Oct 11, 2009 | 1998 Ford Aerostar
How do i reset the tpms on a 08 implala SS after a tire rotation,without a owners manual
You have two minutes to match the first tire/wheel position, and five minutes overall to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions the matching process stops and you need to start over.
The TPMS sensor matching process is outlined below:
  1. Set the parking brake.
  2. Turn the ignition switch to ON/RUN with the engine off.
  3. Press the Remote Keyless Entry (RKE) transmitter's lock and unlock buttons at the same time for approximately five seconds. The horn sounds twice to signal the receiver is in relearn mode and TIRE LEARNING ACTIVE message displays on the DIC screen.
  4. Start with the driver side front tire.
  5. Remove the valve cap from the valve cap stem. Activate the TPMS sensor by increasing or decreasing the tire's air pressure for five seconds, or until a horn chirp sounds. The horn chirp, which may take up to 30 seconds to sound, confirms that the sensor identification code has been matched to this tire and wheel position.
  6. Proceed to the passenger side front tire, and repeat the procedure in Step 5.
  7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5.
  8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. The horn sounds two times to indicate the sensor identification code has been matched to the driver side rear tire, and the TPMS sensor matching process is no longer active. The TIRE LEARNING ACTIVE message on the DIC display screen goes off.
  9. Turn the ignition switch to LOCK/OFF.
  10. Set all four tires to the recommended air pressure level as indicated on the Tire and Loading Information label.
  11. Put the valve caps back on the valve stems.
Aug 31, 2009 | 2008 Chevrolet Impala
The alarm clock on the nokia 1661 goes off before the time set,have to reset alarm everytime, multiple times throughout the night.
Apparently there's a bug in the auto time update function - turn off auto time update and the alarm will work correctly.
Jul 27, 2009 | Nokia 1661 Cell Phone
Have a series of 5 chimes 5 times believe its
The secondary air bag warning is an audible fault format that consists of five sets of five tone bursts, with each set of five tone bursts separated by a five second quiet period. One tone burst cycle will consist of one second ON and one second OFF. This series of five activations is repeated every 30 minutes.
This will tone if the air bag indicator is inoperative.
Suggest to have the dealer or someone with a scan tool that will communicate with the restraint system retrieve codes.
Mar 16, 2009 | 2002 Ford Escape
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
129 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
