Question about Whirlpool GH7155XHS Microwave Oven
How to open the control panel to troubleshoot no power failure condition?
My Mom's Whirlpool RM278BXV-4 built-in microwave oven quit working soon after she pushed the start button. Now it has no power at all - no light, and the control panel display is blank. The conventional oven at the bottom has a light when we open the door - so we know power is getting to the unit.
It looks like the problem is a fuse or the control module itself...
The problem I'm having now is that I can't even open the control panel for further troubleshooting. I turned off the breaker at the wall and removed the 2 screws at the top of the panel and now the top can tilt forward a little bit. Then I tried to push it up to unlock it from the tabs at the bottom so I could pull it out, BUT it is really hard. It almost seems that there are other screws securing the panel, but I can't see it.
Could anyone help me and describe how to remove the control panel so I can access the circuit board and/or the fuse(s) to troubleshoot the problem further?
Thank you very much in advance for your help.
  • Whirlpool Master
  • 9,098 Answers
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we now have a video available showing how to remove a typical control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 02, 2008
I have a Whirlpool old model # RM278BXV-3 and it has started shutting all the way down when heating things up. Contol panel goes blank and quits heating.
Sounds like the control panel. All the other parts are just brute force parts and either work or they don't. Over heating components on the control board are the probable cause.
Dec 30, 2014 | Whirlpool Microwave Ovens
The cooktop lights of my whirlpool microwave have quit working and both bulbs are in good condition. I know how to access the fuses. which fuse needs to bee replaced?
In some cases, it may be a fuse on some Whirlpool models, but your control circuit board may need repair, too.
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing. It will help you find the fuses. See video link below.
We see (and repair) this type of board failure a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one year guarantee.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Or you can order a new control circuit board from the Pros here, our favorite supplier.
Jul 09, 2011 | Microwave Ovens
I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
The microwave oven may be provided with a self diagnostic routine that can be operated
through the touch pad keyboard. To enter the self-diagnostic routine:
1.While pressing the CANCEL keypad:
a) Open the oven door.
b) Unplug the microwave oven for 2-seconds and plug it back in.
c) Release the CANCEL keypad and close the oven door. You will see the following display.
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
POWER FAILURE & FAILURE CODES
Power Failure: After a power failure, the WELCOME screen will be displayed.
F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 Microwave Relay Failure: Check the microwave relay.
F7 Microcomputer Board Failure: Change the microcomputer board.
Hope helps.
Apr 12, 2011 | Whirlpool Microwave Ovens
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
Aug 04, 2010 | Whirlpool GH5184XPQ Microwave Oven
Have an older model (RM278BXV) Whirlpool microwave
what is the problem with it im guessing it prob doesnt heat, if so prob need to get acess inside and check components i would recommend getting a service call as some componoents inside are still live even when unplugged,, it might require a magnetron which would be fairly expensive but if u dont wana replace it than i guess its your only option.. hope this helps
Feb 07, 2010 | Whirlpool GH4155XP Microwave Oven
Kenmore 401.8008700 ran 10 minutes thought I'd set on timer
It could be the fuse. You will also need to check the condition and alignment of the door switches.
Eric
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Keypad on microwave wont work
CHART
NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "—" is displayed...
POWER FAILURE &FAILURE CODES
F2 —Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
F3H —Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
F6 —Microwave Relay Failure: Check the microwave relay.
F7 —Microcomputer Board Failure: Change the microcomputer board.
Oct 18, 2007 | Microwave Ovens
Microwave ahs power but doesn't heat.
check the magnetron and related circuit and high voltage fuse and high voltage diodes, etc..
Sep 24, 2007 | Whirlpool GH4155XP Microwave Oven
Whirlpool GH7155XHS Microwave Oven Logo
172 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
