I have three picture for one - Televison & Video
  • 8,617 Answers
You need new convergence ICs. Please respond to this post with the model number of your set and i will post the correct ICs that you need.
Posted on Jul 24, 2008
Sound no picture 56h80 toshiba
This set will blank the picture for several different reasons:
No filament voltage to the three tubes it uses.
No high voltage to the three tubes it uses.
No vertical or horizontal sweep (prevents all three tubes from having the screens burnt with a line.
Some of these can be tested but most require a schematic etc.
Set has several fuses and some do not look like fuses--called pico fuses.
Jun 11, 2012 | Toshiba Televison & Video
Picture too dark. Particularly noticable during night scenes in movies. Adjusting brightness all the way up helps, but not enough.
hi,
Try to claen the top of three crt guns inside you tv. also the reflecting mirror behind the screen.
one more thing you have to check, that is the CRT base sockets. After some years of use its contact will become bad. As there is three crt guns there will be three crt base sockets on the neck of each. Replace all the three crt base sockets at the same time. It will improve picture quality.
ok
Jul 09, 2011 | Toshiba 51H84 51" Rear Projection...
1 wallpaper per screen? how to set image on per screen lyk 1 pic on 1st n another on third...??
Hey there,
Sorry but the Corby does not have an option to place three different pictures as your wallpaper, it only allows one picture.
A way around this would be to take three pictures that you want to use and combine it into one picture using your computer and then loading that onto your phone. This way it is one picture but it will look like three pictures on your phone
Hope this helps!!
Mar 01, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
The picture looks like it is collapsing in (from all sides) and there are three different pictures...one red, one blue and one green. I have tried to adjust the three picture issue, but nothing seems to...
May be a power supply problem, as the voltage falls the picture suffers. Any power failures in your area? If your line voltage is down it can make for a bad picture.
Feb 09, 2010 | Zenith A50M91W 50" Rear Projection...
Picture has three projections
Replace convergence ics and check resistors in the area. Do alignment.
Dec 06, 2009 | Philips Magnavox 9P6034C 60" Rear...
Panasonic DMC-LZ3 takes three pictures with one click why?
You have it on "auto bracket". Press the up button of the 4-way controller twice. Then you should be able to select on or off.
Aug 25, 2009 | Panasonic Lumix DMC-LZ3 Digital Camera
Sony KP53HS30 Picture Problem
correct, both ICs would be replaced for better performance of TV.
Dec 26, 2008 | Sony KP-53HS30 53" Rear Projection...
The scanner copies three photos as one
Assuming you're using the Epson Scan software, select Home or Professional mode and click Preview. When the preview image appears, draw a marquee around each of the three photos. (Note that as you draw each marquee the number beneath the little image of a marquee - the white square with the dotted line around it - increases.) After drawing your marquees, click the All button, then click Scan. The scanner should make three separate passes in succession, producing three separate images.
Nov 24, 2008 | Epson Perfection V200 Flatbed Scanner
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
