Question about RCA Universal Remote Control
Remote control bought rca universal remote ( rcr 4258 / rcr 4358 ) for magnavox tv model rr 2540 A104. Can't figure out what code # to key into new rca universal remote.
  • 2,071 Answers
Http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): remote control - clip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
I cant find my roku remote any idea if I can use another universal remote? I also need the rca universal remote codes for rcr 311b1 for a magnavox dvd player..
you can buy a new magnavox remote at amazon.ebay and a whole lot of different places. you can also check online to see whitch product the different universal controls support. but usually the original remote is better as its set up for the spesific product rather than support everything from tv, dvd to air cons in some cases
Nov 22, 2014 | Magnavox Televison & Video
Lost codes for rcr450c3642p remote for magnavox tv
Hello
Setup codes to check with Magnavox tV with RCA RCR 450 reome control are
1004, 1014, 1046, 1051, 1060, 1061, 1062, 1066,1067, 1072, 1073, 1074, 1075, 1076, 1077, 1078, 1082, 1083, 1112, 1136, 1161, 1164, 1166, 1176
OK
Sep 13, 2011 | RCA Universal Remote Control
I have a magnavox tv/dvd combo. and a rca universal remote but I lost the book of codes. can you help? model # rcr412s
Hello
RCA RCR 412S remote control has no setup codes with Magnavox TV/DVD combo. Just look for any other brand remote control. OK.
Jul 23, 2011 | RCA Universal Remote Control
Help with GE universal remote control need code for magnavox TV?
Try this link and select the RCR451 and try the codes for it, if they do not work try the one for the RCR 460 one. Just scroll to the bottom of the page and look for the word next, click it and you should see the 460 on the bottom left.
May 30, 2009 | RCA RCR450 Remote Control
I have a rca remote control model RCR 450 and a GoldStar tv
goldstar television code: 004
press code search on remote
press tv on remote
enter code 004
press power on remote
Nov 12, 2008 | RCA Universal Remote Control
Big button remote rcr 4258
does not have all the codes for every product,
Please give me the model # for the cable box -scientific Atlanta and the model # for Magnavox T.V.
also goto www.replacementremotes.com (336)969-1842
They will find you REPLACEMENT remote control CODES, not remote control
Apr 12, 2008 | RCA Universal Remote Control
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Televison & Video Logo
170 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
