Question about Philips Audio Players & Recorders
Philips FW-C399 Radio/CD Player. Getting "Disc not finalized" when trying to play regular CDs,although it will play CDs made by myself viz. CD-R CD-RW. Have not been able to clean lens as machine will not read cleaning disc.
SOURCE: car radio is not reading any cds or dvd
You need to disasemble the stereo and clean the laser lens manually
Posted on Jun 23, 2009
  • 133 Answers
SOURCE: MY CD PALYER DOES NOT WORK. ''DISC NOT FINALIZED'' IS DISPLAYED.
If your CD player has been working for many hours and cleaning the lens didn't help, then the next thing to do is changing the spindle motor (the one that spins the disc), since the brushes and the commutator get dirty/oxydized with many hours of performance.
The motor can also be cleaned, but it's kinda complicated and delicate to do it, so you might want to change it instead.
The same holds for the slide motor (the motor that changes the position of the laser pickup).
To clean the motor you need to desolder/remove it and open it up (you need to bend out the clamped parts on the motor housing to release the cover - also, mark the position of the cover so you can put it back in place in the same position as it was prior to opening it - some motors have an indentation so that the cover fits in place in only one position).
Then you need to remove the cover (this is a delicate procedure as you can easily damage the brushes).
You can clean the brushes and the commutator using a long pointed scalpel - gently scrub away the brownish/black residues on both the brushes and the commutator.
Now you need to put the motor back together, taking care not to damage the brushes when you put the cover back in place (kinda tricky but it can be done).
After closing it, see if it runs smoothly, you may want to try and run it on some 3 volts - it must run quite silently, with no more than a gentle humming sound.
If it runs ok, you should use a tiny flat screwdriver and a small hammer to bend the housing edge back onto the cover to fix it in place (basically, you need to rehammer back in the clamps that held the cover in place, this is also a bit tricky and delicate thing to do).
Now reinstall/resolder the motor back in place (motors on some brands/models can be worked without removing them).
Well, i've just told you how i repaired quite some CD drives which were virtually dead, i'm actually still using a yamaha which is more than 15 years old (i myself have been using it for at least 10 years now), i got it as a scrap piece, it returned to life after the above described procedure and it actually works perfectly up to date.
Anyway, i guess the easy way is to simply replace the motors (they need to have the same axis dimensions and mount holes as the original ones, also they need to run on the same voltage - things to keep in mind when you are looking for new motors).
Hope you can get it working...
good luck
3rq8 (Triarcuate)
Posted on Jul 24, 2009
SOURCE: My JVC cd player, plus Mini disc, and radio. CD will not play
Thank you for your email. The problem must have been dust. I kept putting the cleaning disc in for quite a number of times. Thankfully the problem was simple and it is playing super.
Kind regards to all.
Tonytopaz
Posted on Oct 13, 2009
  • 4 Answers
SOURCE: Can't Read Disc
You could try updating the firmware.
Posted on Jul 29, 2010
  • 5370 Answers
SOURCE: Yamaha MusicCast won't record cds
This error "disc error", "no disc present" or " can\'t read cd". This all error are related to lens problem.If the lens is dirty or if the lens is got cracked or if the lens is getting blocked then it can happen.The lens is very thin glass material.You can say the lens is the "eye" of the unit.If the eye is dirty then it will not see the object.The unit needs to be opened carefully and this lens has to be checked.If any dust is collected clean it.Using the cd lens cleaner helps,but if the dust is got stuck hard or if its any other internal part then the lens cleaner will not help.If the lens is got cracked then the lens assembly has to be replaced. You can use dry tissue to clean the lens.once the unit is opened.------------This will help.Thanks.Helpmech.
Posted on Dec 14, 2010
Hello. I have a Philips FW-R88 CD player that I think I bought about ten years ago. A while back, it started turning itself off and then back on randomly (usually after playing somewhere between thirty...
Clearly some kind of power supply issue as it is on both devices. It might be faulty capacitors or something wrong with the voltage control circuit.
Nov 27, 2017 | Philips FWR88 CD Shelf System
I recently purchased a Philips MP3-CD player and I wasn't sure it it will play regular commercial CDs as I don't think they are MP3 files.
It should play store bought cds. It may not play cd-rs of any type. Look at your owners manual to see what types of discs it can play.
Mar 22, 2011 | Philips Audio Players & Recorders
I have a 2005 Jeep grand cherokee...with a 6 disc cd player. It has worked fine for 3 years since i bought the vehicle...(i used burned cds in it usually) and all of a sudden it will not play or read the...
this is a typical problem with the factory stereo. usually there is nothing you can do for the Cd player, because most likely a cd got jammed and broke or bent some internal components. however try usig a credit card to help eject. insert it partially into the slot and pull out if the cd tries to come out. if this doesen't work then you will have to have the cd removed by tearing it apart. this usually ends up with at least one or two scratched cds and a deck in a million pieces.
Jan 18, 2011 | 2005 Jeep Grand Cherokee
Philips mc235B/37 CD player no longers plays CDs. I get a "No Disc" error or an "Error" message. CD's often don'teven spin. If they do, they spin slowly, then stop, and start spinning in reverse before...
if you can see the laser then gentaly with a soft cloth wipe the lens
and then try
if that doesnt work then i recoment that you call philips and see what they say because it is slightly older than one year they might replace it for free
if not call the shop that you bought it from
May 09, 2010 | Philips MC235 Shelf System
CDs are stuck and CD player will not work. Factory six-disc radio. New CDs.Third new factory radio with same problem. Any ideas on getting the CDs out?
From everything I've heard, this is a very common problem and can be costly to have repaired. One forum I found had this posting...maybe it will work for you.
"This is what I did to my In-Dash 6 disc CD Player.
Rather that toss the radio like most are saying to do you can try this first.
Pull the radio out and remove the screw on each side and the 2 on the back. Pop off the cover and you can see the CD's. The part of the CD changer may have not fully engaged the CD it wanted to play and it is stuck not knowing what to do. Press on the CD that so that the part that spins the CD is locked into the center of the CD. Leave the top open and plug in the CD player. It should start going through all of the cd's then if the CD error is gone it will play again."
Jul 31, 2009 | 2002 Ford Mustang
My recently made music CD will NOT play in our Philips FW-R7. It will play on all our computers and DVD players. The message is "Wrong Disc." Other music CD we've made do play fine in the FW-R7.
This is common with burned cd's they have trouble playing in different sets. Do prerecorder cd's play fine in your philips? If those are having trouble also you could improve it's playability possibly with a cleaning of the opu. Optical pick up.
Jul 17, 2009 | Philips FW-R7 CD Shelf System
CD player won't play CDs
Try getting a cd cleaning tool come with a disk with tiny brushes on it and cleaning solution to clean the eye or if you are using burned cds try and see what format you are buring such as mp3s mp4s some cd player only will play a certain formats such as mp3s.
May 07, 2009 | 1993 Saturn SL1
Frmtread error
how can it solved?? My old mp3's work perfect, now i made a new mp3 cd on the 700 MB space, but it doesnt work anymore.. i get ERROR 23 on my display.. what to do??
Jul 02, 2008 | Pioneer DEH-P3500 CD Player
Kenwood KDC-2025 won't play CDs
source http://www.kenwood.nl/support/veelgestelde_vragen/ Changer Error Codes ? E-00: Poor Cable connection. ? E-01: Magazine not properly set in changer. ? E-02: No Disc in magazine. ? E-03: CD does not have selected track number. ? E-04: Disc is dirty, upside down or unreadable. ^^^^ ? E-10: No data is recorded on the MD. The player plays the next disc automatically. ? E-99: Changer malfunction, disc may be caught in machine or changer requires service. I suggest the lens needs a clean, or someone has dropped it and broken the delicate lens mech. Luck
Apr 30, 2007 | Kenwood KDC-2025 CD Player
178 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
