Question about Arris SURFboard SBG900 (49402201900) Modem
Changing infrastructure mode to ad-hoc mode
Modem is set to ad hoc mode and wireless link on the laptop is going to infrastrucute mode. How do I get that changed so they both are on the same mode? Wireless is saying connected at 100% but still can't access interent on the laptop.
5 Suggested Answers
kousti
  • 41 Answers
SOURCE: Link light on the modem green or orange
the first 4 lights should be gree then the fith orange and should be flickereing on and off fast the last one should be doing nothing
Posted on Dec 19, 2007
Mrvica
  • 167 Answers
SOURCE: Motorola modem SBG900
you must define DNS and Gateway!!! Go on My Network Places, right click, again right click on your network, select properties, TCP/IP and in there enter needed IP addresses!!!
Posted on Jan 25, 2008
ohms
  • 1879 Answers
SOURCE: ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Posted on Jan 26, 2009
  • 102 Answers
SOURCE: Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Posted on Feb 08, 2009
beeveez
  • 167 Answers
SOURCE: cannot make a wireless connectiio work with Comcast internet
- Once you already configured the settings on your router, and 2nd step that you do now is to power cycle the modem and the router completely for about a minute.
Note:
- You must also remove the battery back up of your cable modem in order to refresh the settings on it.
- After the power cycling procedure, turn On 1st the modem and make sure all the link lights on your modem are completely stable before you turn On the router.
Posted on Mar 10, 2009
How do I set my Netgear router to infrastructure mode
Log into your router useing network genie or 192.168.1.1 go to your setup and there you will find what mode you are in then set it there.
Feb 03, 2012 | NetGear WNR1000 Wireless Router
How do I set my linksys WRT300N router to infrastructure mode vs adhoc mode? I have a magnavox blu ray player with wireless capability, it says I have to set my wireless router to infrastructure mode vs ad...
http://compnetworking.about.com/cs/wirelessfaqs/f/adhocwireless.htm
http://compnetworking.about.com/cs/wireless/f/infrawireless.htm
Question: What is infrastructure mode in wireless networking? Answer: Infrastructure mode wireless networking bridges (joins) a wireless network to a wired Ethernet network. Infrastructure mode wireless also supports central connection points for WLAN clients. A wireless access point (AP) is required for infrastructure mode wireless networking. To join the WLAN, the AP and all wireless clients must be configured to use the same SSID. The AP is then cabled to the wired network to allow wireless clients access to, for example, Internet connections or printers. Additional APs can be added to the WLAN to increase the reach of the infrastructure and support any number of wireless clients. Compared to the alternative, ad-hoc wireless networks, infrastructure mode networks offer the advantage of scalability, centralized security management and improved reach. The disadvantage of infrastructure wireless networks is simply the additional cost to purchase AP hardware. Note that home wireless routers all feature a built-in AP to support infrastructure mode.
Feb 02, 2011 | Linksys WRT160N Wireless Router
My wifi doesn't connect to any routers but it connect to my laptop ad-hoc.Still i am not able to use internet through ad-hoc.I have tried restoring my iphone, reset and erase settings, reset network...
Ad-hoc is a computer to computer connection.
You need to change the wireless configuration to Access Point (Infrastructure) mode with encryption.
Your wireless card in your computer or laptop needs to be configured with the router's wireless settings eg. the SSID and encryption key
The encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 30, 2010 | Apple Cell Phones
I need to change to infrastructure mode
Infrastructure mode just means that you're connecting to a router as opposed to a computer to computer connection (or device-computer/device). Since it is a router it doesn't have ad-hoc and infrastructure modes.
What exactly are you trying to do? If you want to connect a pc/device to your network, then just find the network and connect, you'll be in infrastructure mode.
Nov 27, 2010 | Linksys Wireless-G WRT54G Router
Is this is a wireless printer - how do I set up a wireless network from my new laptop to the printer?
Yes your printer is wireless, there're two ways to connect it wirelessly, 1. Ad-Hoc Mode and 2. Infrastructure Mode.
Your can check out the complete tutorials here..
1. Infrastructure Mode wireless setup (recommended)
2. Ad-Hoc Mode Wireless connection
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 23, 2010 | HP LaserJet 1320 Printer
What is infracture mode
'Infrastructure' mode allows you to connect to a wireless modem or router the same way a laptop would. By contrast, ad-hoc mode connects directly to another psp.
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Internet
Go to www.playstation.com and select your country, then select PSP. You can find all kinds of instructions for how to do Internet, download and a whole lot more.
Nov 06, 2007 | Sony PlayStation Portable (PSP) Console
Using psp as compter
Getting online with your PSP is very simple. First, you must be in range of a Wifi hotspot (wireless local area network). You can adjust network setting to connect to an access point such as a Wi-Fi hotspot or the router on a wireless home network and save the network connections data on your PSP®. Up to 10 connections can be saved.
Once in range of the hotspot, go to "Settings" menu, >> "Network" Settings and press "X" Button. Select "Infrastructure Mode" or "Ad Hoc Mode" and press X Button. Set up the "New Connection". For details about Infrastructure Mode set up, or Ad Hoc Mode set up, visit us.playstation.com. hope this helps.
Nov 05, 2007 | Sony PlayStation Portable (PSP) Console
Internet in psp
Once in range of the hotspot, go to "Settings" menu, >> "Network" Settings and press "X" Button. Select "Infrastructure Mode" or "Ad Hoc Mode" and press X Button. Set up the "New Connection". For details about Infrastructure Mode set up, or Ad Hoc Mode set up, visit us.playstation.com.. hope this helps.
Wireless
ensure the modes are matched (ad-Hoc or infrastructure) and SSID and channels match.
Jun 09, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
Arris SURFboard SBG900 (49402201900) Modem Logo
64 people viewed this question
Top Arris Computers & Internet Experts
Suddenlink Help
Level 1 Expert
 John
John
richie46
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
