I wish to record live surgery onto a sagem hard drive dvr. i am looking for a cable which connects an svideo port at the back of my camera unit to the spdic port of the sagem dvd recorder.can u help? its urgent......thanks.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Hi Thanks
for using FixYa. Please see the link to hook up DVR with camera--- Hookup Camera
with DVR Please do
accept the solution if the issue is resolved or post a comment for further
assistance. Thanks Rylee
most dvr units froim cable and satellite companies use a type of copy protection that does not allow you to copy programs to a disc. the cable company wont tell you this but they do and there isnt any way to work around it
The eSATA ports are not configured in the device's firmware, and the USB 2.0 ports are useless except for charging your iPod or powering a USB fan. If you could connect an external drive to the unit, it would be partitioned with data encryption that can only be accessed by the particular DVR that formatted the drive. You can however stream local channels to a video capture card via the firewire ports but cable channels and DVR recorded programs would be encrypted. You can thank the MPAA for the grief...
Buy a recorder that records both +/-R and double layer disks.
I haven't seen a Comcast dvr but you should connect it to the svideo out port of the dvr to the svideo in of the recorder and the audio out to the audio in. If the Comcast doesn't have svideo use the video ports instead
