Question about HP PSC 1610 All-In-One InkJet Printer
Won't print from compter.
Printer will not print from computer.
The copier is working fine.
There are aother printers what do I bring up to be sure that I get PSC 1610?
  • 2 more comments
  • mckuhn Jul 31, 2008
    all the same symptoms..anyone have any luck fixing this and how?
  • Anonymous Nov 13, 2008
    We have PSC1610, printer is doing well for scan and copy, but could not print from one of our note book, it's also working properly when using other computer.
  • Anonymous Jan 12, 2009
    i have an acer aspire one laptop does not have place to load disks so printer not working though laptop
  • Anonymous Jan 13, 2009
    changed computer program printer does not print from computer what do i do everything hooked up fine
Dude! follow instructions given int he quick start guide. you need to install driver and software correctly. so every time you switch on your pc and printer, you can see a message in the quick launch menu "HP deskJet F2100 series is ready". now you can use your pc to print.
Posted on Nov 09, 2008
A document printed from Word on my Lenovo computer (Windows 7 Ultimate) is jumbled mix of different fonts and gives the printer the appearance that it is running out of ink. The same document printed from...
Check the print settings to be sure you are printing in black and white, not grayscale. Instead of clicking the printer icon to print, use the File, Print menu selections to bring up the print settings window.
Dec 03, 2014 | Dell Office Equipment & Supplies
My 9500 series Lexmark won't print, computer says its not communication
1. Check your printer to be sure your printer is listed as installed
2. If the print queue is full it can become confused and just hang up so turn off the printer to empty the queue
3. Power up the printer and send one document to print as a test
4. If the printer works, you should be back in business
Jan 20, 2013 | Office Equipment & Supplies
My printer won't print from computer to printer
hi there,
1- go to your printers folder and make sure the printer is online and your P4350 is set as default (checked).
2- If offline, right click on the printer icon and try to switch it back to online. The same to make it default in case it's not.
2- Once online, then right click on the printer icon again , go to properties and then try printing a test page from windows (I am assuming you are running Windows)
3- In case you were not able to bring it back online, turn off the printer, turn off your PC, reseat the printer cable connection between the printer and the computer (both ends), then turn the printer and the computer back on.
Jun 26, 2011 | Lexmark P4350 All-In-One InkJet Printer
My compter file says that my Cannon imageclass 2300 is offline what is the prolem?
Go to the CONTROL PANEL on the computer, select PRINTER?FAX icon, then click on the name of the printer you want to associate with your printing needs and make sure it is connected. This will allow the print jobs to go..... Please let me know if there is any thing else you might need, of if it is still offline, we can go further! Guy :) Pleasure to help out.....
Sep 24, 2010 | Canon imageCLASS 2300 All-In-One Laser...
I got a message on my computer that said the printer was ''offline.'' Not sure how to fix that. I am connected tot he internet just fine, but I can't print. I lost my manual.Can you help?
1. Open Start menu.
2. Click on "Printers and Faxes"
3. Double-click the icon for your printer.
4. On the menu bar, click "Printer" to open the printer menu. Click on "Use Printer Offline" to remove the check mark. This will bring your printer back online.
Oct 29, 2009 | HP Office Equipment & Supplies
Not printing after a jam
Turn on printer and computer. Remove usb cable of printer from computer. Wait 1 minute and then reconnect usb cable to the same usb port.
Aug 07, 2009 | HP Officejet 5610 All-In-One InkJet...
Computer says printer is offline...HELP
Make sure that the connection of your printer is properly connect, this settings are not detecting the device which to locate the ports its connect.
Connect it properly because this problem is only to make sure not failed to use your printer.
Check it again in your Printer Panel.
Jul 29, 2009 | HP Officejet 4315 All-in-One Printer
Cannot get the printer install it saying the printer spooler is not woking have two more printer said something so brought aother printer i only use one
The spooler is a service running that handles all the printing.
Can you list the exact spooler error?
This page from Microsoft has helped me numerous time with spooler errors, but be sure about the problem as it references editing the registry and this should only be done if necessary
LINK
Dec 08, 2008 | Office Equipment & Supplies
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
CANNOT PRINT WITH NEW COMPUTER
I had many problems with Vista fixed in this way.
1) Unistall drivers supplied with printer
2) Download new Vista drivers
3) Disconnect printer
4) Restart computer
5) Install new drivers (connect printer when it asks)
6) Restart computer
For me it now works.
Jan 15, 2008 | Lexmark Z640 InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
Ben Johnson
