Question about SanDisk Audio Players & Recorders
I have a Sansa e200 series MP3 player. And I recently had my PC crash. I lost all my stored info. So I am trying to reload my device driver from the installation CD (version 1.3). And I am having no luck in doing so. Any Ideas ?
  • SanDisk Master
  • 19,396 Answers
To reinstall software do the following:
  1. Uninstall all Sansa software from control panel/add remove programs.
  2. Restart PC
  3. Reinstall software from disk (keep Sansa USB UNPLUGGED when doing this)
  4. Connect sansa when required by software installation or after installing
If it does not work come back to us.
Posted on Jul 24, 2008
    President:
  • 1,257 Answers
Use this link to find the drivers
http://windowsupdate.microsoft.com/
  • SanDisk Master
  • 13,433 Answers
  • Ekse Jul 24, 2008
    You need to have Sp2 installed, also windows media player 10 or newer
    http://www.microsoft.com/windows/windows...
  • Ekse Jul 24, 2008
    The drivers come with windows media player 10 or newer, so, after you have that installed you should be able to see your sansa in the media player and also in your my computer.
    see the manual pages 11 basic useage.
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
My computer crashed and I lost everything. I now
You can download the Sansa Updater from the manufacturer's web site at http://www.sandisk.com
Feb 07, 2010 | SanDisk Sansa e260 MP3 Player
Sansa 40gb e260 dont know how to put music on it . dont have manuel
For the Sansa e260 4 GB there are 2 versions for the e200 series players:
version 1 manual
version 2 manual
Check the version of your Sansa e200 series:
go to Settings > Info.
SD card compatibility:
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Dec 09, 2009 | SanDisk Sansa e260 MP3 Player
NO AVAILABLE PLAYER DETECTED!
Try going into settings, usb mode change that it should be either mtp or msc.
May 09, 2009 | SanDisk Sansa e200 MP3 Player
Sansa e260 will not power up
Okay what you do for this is hold down the power button for 20-25 seconds or so. This will reset your Sansa e260 and then it will power up like normal. I have had this problem before. If that doesn't work then I don't know what will.
Feb 02, 2009 | SanDisk Sansa e260 MP3 Player
My sansa e280 mp3 player stopped working i dnt knw y
I'm unable to assume the exact problem with your mp3 player as you've bluntly said that the device is not working. Try the following steps and that should work. If not let me know:
  SOLUTION 1 - Reset the device
Resetting the Sansa View/Fuze
Resetting the e200/c200 series
SOLUTION 2
 - Reload and update to the latest firmware
STEP 1 - Enable MSC or Recovery mode
Enable MSC mode on e200v2 / c200v2 / Fuze
Force Recovery mode on e200v1 / c200v1 / e200R / View
STEP 2 - Update to the latest firmware
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??)
 2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer   3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC   4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on).  5. Try other modes as well.
Keep the device in AutoDetect Mode and follow the instructions below:
i. Connect your Device
ii. Right click on My Computer and select Manage
iii. Select Device Manager
iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
v. Right Click on the device and select Update Drivers
vi. Select 'No, not at this time' and click Next
vii. Select 'Install from a list or specific location' and then click Next
viii. Select 'Don't search, I'll choose the driver to install' and then click Next
ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use
Jan 31, 2009 | SanDisk Sansa e260 MP3 Player
My Sansa e260 Mp3 player isn't recognised by Windows and will not show up as connected.
e200 is the generic name for the entire e-series including the e250, e260, and e280. The only difference between the models is the amount of internal memory. The e200 driver is used for all models in the series, and the e200 manual likewise covers the series.
Oct 23, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa m200 series and my macbook pro
It is complicate,
it works on Mac OS only if you downgrade firmware for sandisk.
Here is how to do it.
If system crashes while you install the firmware you will damage the sansa, Mac OX is solid , but be careful with the USB cable.
Here is the procedure: How to use your SanDisk Sansa e200 Series .mp3 player with OS X ...
Here you can also download software
Sep 13, 2008 | SanDisk Sansa e200 MP3 Player
Help i can't open my sansa E200
Go to the place where you bought your Sansa E200 and ask them to have the firmware reinstalled. Most mp3/mp4 players crashes its firmware when you are working on something and the battery goes down. There is nothing wrong with your gadget's harware, just a software issue.. that's all.
A Simple Thank You is Good enough
Feb 15, 2008 | SanDisk Sansa e200 MP3 Player
65 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
