I don't have a sound - Audio Players & Recorders
  • 682 Answers
Please confirm---first power on----speaker button pressed(if you have one)-no mute button pressed--you select the right input source-input interconnect cable is ok.-----------setup of speaker is ok.your output cables to speakers are ok.
Posted on Jul 24, 2008
I don't know how to get all speakers to work
Sounds like your surround settings are not correct. Try selecting a prologic surround mode and see if that turns on all speakers for you.
Dec 26, 2012 | Kenwood VR-207 Receiver
Lxi receiver lights up good fuse no sound is it the tubes? does it have tubes?
I don't think it has tubes. If you have a voltage meter, check to see if you have your plus and minus 15 volts and 7 volts. If you don't, the problem can be in your voltage regulator.
Apr 11, 2012 | Audio Players & Recorders
Hi ! I have a Pioneer AV receiver VSX-D710S and i have a problem with sound ! At the maxim volume (0db) the sound it's verry low an when i make volume ajustments i heard in speakers some knoking !...
The first thing you need to do is to disconnect all the speakers.
Then connect them one at a time and see if you get the correct volume on any of them.
If you don't get the correct volume on some of the speakers then it's those speakers that are faulty.
If you don't get the correct volume on any of the speakers then the fault is with the internal amplifier and you'd need to take it to get it repaired.
Jul 29, 2011 | Pioneer VSX-D710S Receiver
I have a Teac AG-780. The Radio works, good sound out of two Bose 901. But when I click on the CD button and play my CD palyer (JVC XL-R5020) it doesn't sound. BUT! I place a Head Phone jack in it, the...
So what are we dealing with - the CD player or the Receiver?
901 involvement implies you have an Active Equalizer somewhere in the audio path. IT has buttons on it that can interrupt the signal.
What's connected where, exactly?
Jul 14, 2011 | Teac Audio Players & Recorders
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
My Whafedale WH-AV4337 remote switches the unit on and off but will no longer feed the TV sound to my speakers. The AV (Digi) flashes "unlock". I don't have a user's manual. Any...
Hmm, I don't know why the emphasis is in the remote here.
Front panel switches still exist on most products so ramble across the room and try touching it with your finger so we don't have to factor in a possible remote malfunction.
I can't locate a free manual anywhere but YOU should contact Wharfedale and ask them where you could get one because the website only lists a handful of speaker downloads.
http://www.wharfedale.co.uk/Home/tabid/37/Default.aspx
However the digital audio for the "AV" is arriving, it is probably not syncing up or the signal / cable is failing or disconnected. Try swapping with known good cables or input jacks.
Jun 19, 2011 | Audio Players & Recorders
The sound started getting a ilttle bit worse and now Ive rewired it checked everything it turns on then just turns right back off.
UNDO what you did. Get the manual and connect it right. Don't guess.
AS far as subjective sound goes, you need to fill in some objective facts if you want help.
Jun 03, 2011 | Yamaha HTR-5840 Receiver
No audio from monitor
you don`t need a driver for the monitor sounds like the sound card driver
Mar 29, 2008 | Audio Players & Recorders
 Grubhead
Grubhead
