Back to:
Tags:
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer
Brother DCP-135C - "Init unable AF"
posted by Daniel Nix on Jul 24, 2008
I have a Brother DCP-135C. After I removed a paper jam completely, the printer continues to malfunction - when restarted it makes an unhealthy sounding rapid stuttering sound, as if a motor were jammed in someway, and the LCD display reads "Please wait". This stops after about 10 seconds, and I get the LCD message "Init Unable AF". I'm then referred to the Routine maintenance chapter of the users guide. However this sheds little light on the problem.
Any ideas? All suggestions would be very greatly appreciated.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Sep 24, 2008
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I just had the same problem, and it turns out there was still a little bit of paper under the print head. If you unplug the printer, and move the head to the side, you might find the same.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Brother DCP-135C - "Init unable AF":
I don't want to Accept this solution
Solution #2
posted on Jul 24, 2008
Not Rated (0)
culver73
Rank:Guru Guru
Rating: 85%, 43 votes
Sometimes these small machines have a lock to hold the scanner in place for shipping. Check to see if you have one and be sure it is the unlocked position. If you have one it is usually on the left side or under the scanner portion where the paper comes out.
Thank You!
Can you Help with these Printers problems?
Brother Multi-Function Center MFC-240C...
My machine said toner life end - I replaced it with a new...
I am trying to print photos on 4 x 6 paper that have been...
I recently had Verizon Fios installed. Since that date,...
I keep getting message that I need to reload the right...
faxes machines were able to send and recieve faxes ,but...
Loading problems.
Repair Service
Find Printer Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
