Question about Canon PowerShot A630 Digital Camera
INSIDE PHOTOS ARE DARK AND GRAINY
EVEN THOUGH THE FLASH GOES OFF, MY INTERIOR PHOTOS ARE STILL DARK AND GRAINY. I HAVE TRIED RESETTING CAMERA TO ORIGINAL DEFAULT SETTINGS. DID NOT WORK. MY CAMERA IS OUT OF WARRANTY.
ANY IDEAS??? PEGGY VICKERS
PEGGY@PEGGYVICKERS.COM
  • 163 Answers
Regardless of the camera make/model... dark, grainy photos are usually a result of a lighting problem. Looking at the specs for your camera, the flash is only speced for 4m. If you are shooting near or above this you might have trouble. I ended up using an external flash that is triggered by sensing the cameras flash. Pretty inexpensive and pics ar 10x better. Try a local camera shop or B&H Photo (NYC) is where I got mine set up on line.
Posted on Jul 24, 2008
I have a Canon Power Shot A720. Outdoor photos are beautiful. Indoor photos are always grainy/blurry...a lot of noise. I have tried the ISP feature but there are only two choices... 1. Auto or 2....
Hi Usually outdoor picture are good within small compact camera. They designed like that. But now your unit just have flash pcb defective. When flash function work, your picture will be good indoor. Regarding your flash unit would be brown fuse or replacement of flash unit. It is 50 and 50 chance. Your local repair shop would charge around $35 to 95 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Canon PowerShot A720 IS Digital Camera
All of the pictures are grainy and very dark- not usable camera at all- less than 2 years old I have re formatted the SD card, changed the batteries, and reset the camera to default settings
To fix your issue with the Canon Powershot SX110 IS Digital Camera, try cleaning the lens. A huge issue with malfunctioning pictures can be as objective as a dirty lens. If that doesn't solve the issue, try to make sure that your flash is working to its full power. If you are taking a picture in a low-light area and the flash isn't giving off a strong enough light, this will cause grainy/noisy dark photos. Lastly, try playing around the with settings on the configuration screen. Sometimes digital cameras can malfunction, even after reformatting, and will apply alternate settings from what you originally had set.
Hope this helps!
-Anonymity
Feb 24, 2011 | Canon PowerShot SX110 IS Digital Camera
Bad indoor pictures. When I take indoor pictures and it says to use the flash I do but then my pictures turn out dark/grey. Then I try it without the flash and they are brighter but then blury. I even...
The flash has a range of up to around 10 feet at the wide end of the zoom, down to 6.5 feet at the tele end. Maybe you are using it on to big a distance or at to low ISO? Try setting the ISO to 800 and see if it helps. images get a bit more grainy at 800 ISO but are also less prone to camera shake, if you use it without the flash. The camera goes as high as 1600 ISO, but images get very grainy at that setting.
Jul 01, 2010 | Canon PowerShot SX100 IS Digital Camera
Suddently my photos have too much purple and are grainy.
To start remove camera battery for one minute, this will reset settings to factory.
If pictures are all purple and shady , and this is not a setting problem , then it is usually a bad CCD sensor.
On many models (depending on year) CCD sensor repair will be entirely covered by Canon. Give them a call to check it out.
See the related links below:
Canon Powershot Digital Camera CCD Image Sensor
YouTube - Messed Up Camera (Canon A70 CCD Senso
Apr 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Polaroid i1035: Bad quality pictures, appear grainy and fuzzy
The grainy effect has to do do with the ISO setting, try adjusting that. A higher ISO is generally better for darker conditions. I have noticed that this camera frequently takes grainy images.
Jan 29, 2009 | Polaroid i1035 Digital Camera
Flash not working
posted by greenbean on Jul 28, 2006 Report abuse
when i take a picture the flash goes off but my actual picture is dark and grainy. i have new, powerful batteries. The camera is on auto. This is the setting I've used for 3000 pictures and I've never had a problem before now. if(typeof LIB_LOADED == 'undefined'){document.write(''); } Solve This! postsolution.gif Post Solution addwq.gif Work Queue -->sameproblem.gif Have the same problem? --> I have the same problem -->I have the same problem.
X This Problem has been added to the Share Your Expertise Page under "My Work Queue". OK Best Solution posted on Nov 14, 2006 3%20stars.png
noavatar_s.gif Hawic
Rank:nonexpert_s.gif Apprentice
Rating: 90%, 2 votes
I had this problem before, sent it off to have it repaired 1 year ago, and now have it again.
Just to make sure it's the same problem, here's a description: The flash seems to be out of sync with the shutter. Using the flash in medium or low light (in auto mode) makes the picture darker than not using a flash at all. It ruins the picture. In a completely dark room, even though the flash fires, the pictures comes out pitch black.
The problem is the flash unit -- it needs to be replaced. If your camera is under warranty, Canon will replace it for free. (You pay only to ship it to them.)
(You might try what they told me to try before I shipped it off, and that was to reset the camera by pushing and holding the menu button until it resets. Didn't do anything for mine, but who knows.)
If it's not under warranty, Canon will offer to replace it with a refurbished newer model for a discounted price. That's my situation now, because the problem has come back.
I did come across a posting that described how to replace the flash unit yourself -- it involves taking the camera apart, but looks doable. (Sorry, I don't have the link handy and I'm not sure if I can find it back.) The problem is, I don't know where to get the part. Canon has been no help on this. Anyone know where I can get a Canon flash unit for the A85?
Hope this helps, and good luck.
Was this solution helpful? Show your Appreciation by rating it:
Sep 01, 2008 | Canon PowerShot A85 Digital Camera
Grainy, image
You might have changed the settings; ISO setting too high or something else, just reset it to factory settings if you can't figure out ISO.
Aug 21, 2008 | Ricoh Caplio GX Digital Camera
Digital camera
you can try and adjust the contrast for that pictures. try also iso 300 for the picture to increase quality. downpoint is its size will increase. just explore the settings and try them all out. im sure you will find the perfect settings that you'll like
hope this helps.
fixya!
Jan 31, 2008 | Cameras
Dark pictures with flash
I had this problem before, sent it off to have it repaired 1 year ago, and now have it again. Just to make sure it's the same problem, here's a description: The flash seems to be out of sync with the shutter. Using the flash in medium or low light (in auto mode) makes the picture darker than not using a flash at all. It ruins the picture. In a completely dark room, even though the flash fires, the pictures comes out pitch black. The problem is the flash unit -- it needs to be replaced. If your camera is under warranty, Canon will replace it for free. (You pay only to ship it to them.) (You might try what they told me to try before I shipped it off, and that was to reset the camera by pushing and holding the menu button until it resets. Didn't do anything for mine, but who knows.) If it's not under warranty, Canon will offer to replace it with a refurbished newer model for a discounted price. That's my situation now, because the problem has come back. I did come across a posting that described how to replace the flash unit yourself -- it involves taking the camera apart, but looks doable. (Sorry, I don't have the link handy and I'm not sure if I can find it back.) The problem is, I don't know where to get the part. Canon has been no help on this. Anyone know where I can get a Canon flash unit for the A85? Hope this helps, and good luck.
Jul 28, 2006 | Canon PowerShot A85 Digital Camera
Having problems with the flash\ blurred and grainy images
You should not use the flash for these shots (unless you connect a powerful external flash), it won't help you at this distance. You should use the shutter priority mode and experiment with shutter speed (no flash) to get the best result - for sports action it should probably be faster than 1/100 sec. If the light is too low you may use higher ISO setting - 200 or 400 (though higher ISO will result in grainier images, it may be your only option for blur-free photos).
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Canon PowerShot A630 Digital Camera Logo
284 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
