Question about Danby DKC646BLS Full Size / Pony Beer Keg Cooler
Temperatuer gauge says LE
What does it mean when the temperature gauge displays "LE"?
  • Anonymous Apr 18, 2009
    My temp guage says the same thing and it gets too cold..
  • 4 Answers
If your gauge displays LE, it is below 15 degrees F. That means your beer will freeze. The same problem occured on mine. I called Danby and the rep was very helpful. She informed me it was definately a problem with the temperature pad on the front of kegerator. The part cost less than $3 and shipping was $7. It was an instant fix and it was easy to replace. Remove the four screws to the tower on top, the three screws to the rear, and pull the top off. Flip it over and remove the two screws to the computer. Unplug the old and replace with the new. Very simple job. Due to the low price of the pad, I would order two. The shipping price is the same and I don't have to worry about another keg being ruined because I now have a spare on hand. Hope this helps.
Posted on Jun 15, 2009
I have the same problem. Call Danby (1-800-263-2629) and they will either replace the circuit board it if it is still under warranty or they can send you the replacement part. It means there is a miscommunication, i.e. short, in the circuit boards and it needs to be replaced. The replacement cost is only $14.49 as of 4/23/09 not including shipping if you have exceeded your warranty.
Posted on Apr 23, 2009
I have a danby kegerator and the code LE keeps flashing
Sounds like a faulty temperature probe or faulty temperature control circuit. Some modify their unit with an external temperature controller. It does require knowledge of wiring to perform the modification. There are detailed notes, images, etc provided by psychodad at
Thread Danby Kegerator Improvements Part II
Aug 27, 2014 | Danby DKC645BLS Compact Beverage Cooler
Frigidare PLHS67EGSB1 IS 6 YEARS OLD Temperatue Fluctuates On freezer side
Good Morning bernie3003 - For this particular model, the control on the door is the brain which controls all the functions of the unit. If the temperature inside the unit is not reading the correct temperature, then there might be a thermistor or wiring issue between the thermistor and the main control board on the door. I would personally contact a professional to accurately diagnose the refrigerator to determine the root cause to reduce the risk of unnecessary parts.
May 19, 2013 | Frigidaire 22.5 Cu. Ft. Counter-Depth...
What does OF on the display mean?
If you get the message OF on your Samsung refrigerator here is how to correct it. What OF means is your freezer and refrigerator has or is going to stop and warm up. To correct it push the Light+Freezer buttons for 3 seconds. It will reset to the last temp settings and everything should go back to normal.
Feb 06, 2013 | Samsung RS265TDRS Side by Side...
I've owned it for about a year and have not had any trouble. But my Danby Kegerator just started beeping and flashing EE on the display one day and it won't cool. I had to unplug it. Any ideas
An EE error code means that you have loose connections (loose temperature sensor connections) check all the wires for a loose connection
temperature touch pad
the units main control board
the control board is in the back of the unit there is a panel covering in the middle lower back near the compressorInside your unit on the left side in the lower rear theres a vented piece of plastic pry that off thats the temperature sensor make sure all the connections are tight
If the error does not clear then your temperature sensor is faulty
you can get a new sensor at
www.repaiclinic.com.or
or at
www.appliancepartspros.com
hope this helped
Good Luck!
May 01, 2012 | Danby DKC646BLS Full Size / Pony Beer Keg...
Why won't the temperature setting stay and it keeps going to hi temperatue
try a new thermostat ,a universal one will do the job providing it comes with a wiring diagram
Nov 20, 2011 | Frigidaire Refrigerators
Flashing temperature control for freezer setting
There is no problem for that, as long as the temperature control is functioning well and it display the temperature degrees number. You vary it, hi or low and the unit still cold or freezing.
Sometimes the liquid crystal display of the electronic control module become loosen 'cause it to display in a flash manner. Unless it display "ER" it means there's something wrong with your unit. But so far it operate normally.
Thanks for asking.
Jul 04, 2011 | Refrigerators
How to adjust temperature
Hi, Please use your thermostat to adjust your temperature setting. Most refrigerator thermostat is come with actual temperature setting at thermostat dial but it just use range : cold-medium-off ( or 5...5..3....1..0). So for instance to get your refrigerator colder just set between medium - cold. If your thermostat defective , your refrigerator will work unpredictably. In this case you need to fix or replace the thermostat.
Regards, Jay
Feb 28, 2011 | Refrigerators
Viking Wine Cellar Temperature Near-Freezing
Viking wine coolers are made by Marvel.They all had issues with freezing the contents. If you replace the electronic cold control system it will be fine.If you don't, it will freeze the wine popping the corks and leaking in the unit.If you get the parts from Marvell they are much cheaper.
Jun 01, 2010 | Viking VUWC141 Wine Cooler
Keg freezing!!!!
Same problem here. Can you give me their number? cheekychap@bellsouth.net
Feb 20, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
No display panel indications on Fridge freezer
We had the same problem due to a power surge- we pressed the power cool and power freeze buttons at the same time until it reset and it's fine now. Hope this helps!
Dec 29, 2006 | Samsung RS2630SH Side by Side Refrigerator
Danby DKC646BLS Full Size / Pony Beer Keg Cooler Logo
1,023 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
