Question about Sony Network Walkman NW-A1200 MP3 Player
Sony Walkman MP3 Player is still not working.
I hit the reset button all of the time and I hit the reset and Sony Walkman MP3 Player is still not working.
  • Monkeyblank Sep 21, 2008
    Exact same thing - this is brand new, I've spent hours loading all my tunes and now it's just frozen on the logo - nothing is happening ARRRGGGHH!
I need program fo walkman nw-1000 wind vista
Posted on Sep 05, 2008
How do i reset my mp3 player its just frozen?
How Do I Fix My Sony MP3 Player That Froze & Won't Turn On?
Sony Walkman MP3 players, like most MP3 players, can occasionally freeze up and stop working properly. Fortunately, there are two simple ways of resetting the Walkman system. The first method takes only 10 to 15 seconds to complete and is an effective way to troubleshoot most technical problems you may have with your Walkman. The second method, unfortunately, may take several hours; it requires you to allow the battery to drain completely. Whatever the problem is that's causing your MP3 player to freeze, one or both of these methods should clear it up.
Instructions
Things You'll Need:
* Paperclip
* Walkman MP3 player charger
Reset Button
Straighten the paperclip and set it aside for now.
Locate the reset button on your Sony MP3 player. On most models, it can be found near the volume control mechanism.
Insert the end of the paperclip into the reset button and hold it down for three to five seconds. When the screen flickers, you'll know that the MP3 player's system has been reset.
Remove the paperclip and wait for the system to reboot.
Battery Drain
Turn on your MP3 player.
Let the battery's life deplete. Since the system is frozen and no music is being played, this will take longer than usual.
Check that the battery is completely depleted. Sometimes the screen just goes dark during this process, but the battery is not actually drained. You can check this by pushing buttons or trying to power up the system.
Connect your MP3 player to its charger and plug it in to a power source. Allow the MP3 player to fully recharge.
Power on the MP3 player. The system should be operating normally again.
Jan 10, 2011 | Sony NWZE345 MP3 Player
Hello, I have problem with Sony MP3 player NWZ B135F. When I turn on this player, on the screen is sony walkman sign. No digit works, and walkman can not turn off. Just when I push reset button, walkman...
Try flashing the firmware of your mp3 player. Also press rest button while its connected to the computer for the driver to be reinstalled. hope this help.
Sep 29, 2010 | Sony NWZB135F MP3 Player
My sony walkman won't turn on
Thank You DamonJones. Hitting reset on the back with a pin WORKED. My mp3 is back up and running with all songs
Feb 20, 2010 | Sony Network Walkman NWZ-S545 Digital...
I can't put any tracks on the player because the computer says player is full even though there are is nothing on it and I've hit the reset button several times. Yes I've cleaned out disc space onthe...
Probable cause. Computer Virus, Disk Space Error, Disk Space damage. Try to formatting it using the settings in your Walkman or in the computer you can format the disk of your Walkman. after you have it done, try to do your task and if it's still not working contact the service center ASAP.
Jan 26, 2010 | Sony Walkman Video NWZS615F MP3 Player
Frozen
hi mine freezes too when i try to open my photos on the walkman. but mine did work using the reset button, you might want to return it if you have receipt, if not you still got 1 year warranty with sony.you can also try connecting the player to the computer to see if it turns on and charges. thanx
Dec 25, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sony walkman 4GB NO RESPOND/FROZE with screen saying"WALKMAN"
Get a pin and push the reset button located at the bottom of the unit. Hope this will help.
Dec 02, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sony mp3 player model no.NWZ S616F - screen frozen
hit the reset button with something sharp at the bottom of the walkman
Nov 24, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sony Walkman NWZ-S615F problem detecting and syncronizing
I had the same problem. One day my Mp3 started acting weird and said it was not recognizing the files and that i needed to re download them. Try plugging it up to your computer while its charging and hit the power off. Then reset your mp3 with the button at the bottom and it should recognize it.
Nov 17, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
My Walkman is going berserk
when that happens you want to get some thing sharp and hit the reset button on the bottom of the Walkman
Aug 10, 2008 | Sony Walkman NWZ-S616F MP3 Player
Sony Network Walkman NW-A1200 MP3 Player Logo
709 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
