It could be a capacitor issue, if you will be able to open the organ from behind, look for a piece that looks like the picture below and check if it is almost bursting or ballooning,( like when you put some Coke in a plastic bottle then shake it until the bottle almost pops), if you see them like that, that means they may be damaged and must be replaced. check the catalog here
Hammond organ parts
good luck
Posted on Jul 25, 2008
I think there is no defected parts, it is only loose or crack or cold solder joints connections to the circuit board.This is a common problem "you done nothing and then it's not works"...
Cold solder issues - each
component is soldered into small
holes on the printed circuit board which in turn connects said
component to the
other components. Due to time, heat, use, some solder joints would be
cracked
or loose. It is possible that the cold solder is still minimally
connected
(hanging by a thread). When the Hammond organ turns on heat would be
generated which would
be sufficient to further loosen up the solder joint to the point it no
longer
provides electrical contact. Jarring the unit creates movement inside
enough to
re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly
probable that there are no defective components. As you have surmised, it is
possibly a loose connection, solder joints are "connections"
except that molten soldering lead is used to attach/connect the component to
the board, "loose connection" in this sense is equal to "cold
solder".
Again on the assumption of no defective parts, then seeking a more
experienced
buddy for the soldering might be to your advantage. This is of course
in
addition to the possible electrical hazards when repairing.don't forget
to rate ;this is the only way i get paid for my works thank you in
advance..
Good luck:
The only way to find out what the problem is to open it and check any fuses in there, if all the fuses appear OK next step would be to measure the voltages from the power source to the rest of the circuitry.
I would suggest to contact this website for parts availability and they might be able to help you.
Posted on Jul 24, 2008
It sounds to me like it blew a fuse. Open up the organ and look around where the power cord enters the internals. There should be some sort of inline fuse there. If there is simply relace it with a fuse of the exact same value and type.You can bring the fuse to radio shack and they will help you locate the proper fuse. You can get a little pack of four for a couple of dollars. Also make sure you are getting power to the organ. Have you checked the outlet it is plugged into? Plug in a lamp or other device and make sure there is power to the outlet and the plug is in it securely. If you need more help feel free to ask me. I hope this was helpful....
George
Either the motor has blown or the resistor before motor contact is gone.
Here you can find all Hammonds replacement parts, and ask consultancy on faults and parts needed.:Hammond Organ & Leslie Speaker Parts
Regarding the fault, probably the motor has blown, in my old hammond there was also a variable resistor before the motor that blew up. You can check this out by accessing the motor.
You can also find parts and hints here:
Hammond Organ and Leslie Speaker ...
To get the fuse you need to take it apart, the fuse is in the power supply, where power cord hook in.
Nov 13, 2016 | Electrical Supplies
Jan 17, 2018 | Ruud Heating & Cooling
Sep 02, 2011 | Behringer MS16 Monitor Speaker
Feb 16, 2011 | Yamaha 2300 Watt Generator - EF2600
Jan 25, 2011 | Xantrex Technology Heart Freedom 20 12...
Jan 18, 2011 | Nespresso Citizmilk C120
Aug 21, 2009 | Sony STR-DG520 Receiver
Apr 26, 2009 | Kenmore 22642 Top Load Washer
Jan 18, 2009 | GE Profile JT952 Electric Double Oven
Jun 13, 2008 | Kirby Vacuums
81 people viewed this question
canot find fuse
I can not find the fuse.
I found the power cord
I cannot find the motor on Hammond organ T524C
