Question about Magic Chef 31000 Gas Kitchen Range
Lighting pilot light on magic chef gas range
The broiler does not heat up on magic chef gas range. How do I know that gas is getting to the burner? The top four burners work fine, but the pilot light for the oven and broiler, I don't think is on. Please help
Jim G
  • 1 more comment
  • gorsin Jul 25, 2008
    The range is a 2003 year. There are no red buttons on the oven knob and I don't see a pilot setting. The oven knob turns and depresses. Does the depressing start the igniter? When I turn on the knob and look into the broiler area should I hear hissing because I don't hear any hissing It sounds from your comment that it is an electric spark starter. As I look at the region where the pilot is it does look like an electric igniter. Is there a battery somewhere in the system to cause the spark.
    Jim
    Thanks for the help. I found out that I was not keeping the oven control in long enogh for the T/C to heat up and keep the gas flowing to the pilot. I works fine.
    Thanks again
    Jim
  • Anonymous Mar 14, 2014
    pilot burners dont light
  • 2,071 Answers
  • 6,487 Answers
You should start by measuring the current flow to the bake ignitor, or checking to see if the ignitor is even getting voltage. There are articles on what to measure on ignitors and how to make basic electrical measurements .
If the ignitor is not getting voltage at all, then trace the circuit back to find where the voltage is getting interruted. Thermostats are common culprits.
-Sounds like your oven has a separate ignitor for bake and broil. If so, your valve is a two-port valve and you should check the bimetal in the bake port to ensure that it hasn't been blown.
Hope that helps..............
Posted on Jul 24, 2008
    Master:
  • 382 Answers
Hello Jim,
Try to replace the ignitor if it is more than 3 or 4 yrs. old..If it not that old then Turn the knob to the pilot setting and depress the handle. Holding it down and at the same time, press down on the red button that sparks. You may have to repeat this a few times. Once the pilot lights, continue to hold down on the pilot knob for about 30 seconds. When you release the knob, the flame should stay oN. If it does not, replace the thermocouple. Once the pilot flame is steady, turn the gas valve knob to on!!!..Thank you...
Hope this helps you!!...
Regards!!!....
  • Magic Chef Master
  • 19,396 Answers
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
How do i re ignite the pilot light
Hi
The surface on this range have standing pilots that must be lit initially. To light them:
1. Be sure the surface burner control knobs are in the "OFF" position.
2. Remove the grates and cook top.
3. Locate the pilot ports and light each of them with a match. Replace the cook top and grates.
Light the oven burner pilot in the following manner:
1. Be sure the oven control knob is in the "OFF" position.
2. Remove the broiler carriage.
3. Hold a lighted match at the top forward section of the pilot (See diagram). No adjustment is required.
4. Replace the broiler carriage.
Hope this helps...
Daniel
Aug 28, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
I have a model 3110PRW gas range and can not get the pilot lights to light. I am getting gas through as I can light all four burners but the pilots will no ignite. It is set up for propane gas.
Hi on the burners there is a hole where the gas comes out of the burner to light off the pilot is this blocked or are the pilots blocked short pilot flame
Feb 09, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic chef oven pilot light out
Hi, If the oven has a standing pilot too, Open the bottom door and locate the main burner. Follow the burner toward the rear of the oven and there will be a flame switch attatched to the burner. Hold the flame near the flame switch and the gas should ignite.
Some model do not have a standing pilot in the oven. Please get me your model number off the label located around the opening of the lower door so I can look this up and instruct you better.
Vic
Jul 15, 2009 | Magic Chef 31000 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
Oven not working - strong gas ordor
man that is an old oven, according to the diagram ther is a pilot light in the oven compartment , access form the lower drawer/ cover panel, looks like a pilot for sure and problably has blown out
Nov 25, 2008 | Magic Chef 31000 Gas Kitchen Range
Oven not lighting
Sounds like the ignitor in the oven is weak and not building up enough resistance to the gas valve to allow gas to the burner. I would replace the ignitor if it is more than 3 or 4 yrs. old.
Oct 05, 2007 | Magic Chef 31000 Gas Kitchen Range
Magic Chef 31000 Gas Kitchen Range Logo
504 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
