Printers
Problem for HP Printers
Generic problem for all HP Printers
Hp photosmart c3100
By shilohklaus on Jul 24, 2008
software won't install trying to hook up c3100 to dell vista home premium inspiron 531
Solution #1
posted on Jul 24, 2008
Not Rated)
JackHeath
Rank: Guru
Rating: 85%, 216 votes
Recommendation:
Make sure that java, direct X, and .NET components are up to date. Many installers not require these.
If the install just can't see the printer, I would completely uninstall any components you were able to get installed (if any), remove the device entirely from your system, download a Vista version of the driver from HP if possible, and run the setup.exe...If your using a system driver you'll have to hook the printer up first, otherwise when it asks you to attach the printer then hook it up in a different USB port.
If all else fails install the drive manually through the control panel using Add Harware and then browse for the INF file.
Reasons
  1. Downloading the driver gets you the newest version available and may resolve a bug.
  2. Changing the USB port will keep Windows from using the pre-configured settings set up in previuos installs.
  3. Installing manually will add the printer to the device library, even if you have to reinstall it a second time to get the USB configuration right
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
konika minolta 1600 magicolor
Answer
McAfee VirusScan Plus HP Customers-Buy Now & Save. I tried www.hp.com/go/deals5 . could... (More)
Answer
Can you please help? I have a Canon MP 210 and a message comes up with "Your Ink Absorber if... (More)
Answer
My Brother 5240 laser printer has a red status light when i turn it on. I hit cancel job, and the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Printers:
Top Printer Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
