You have to have a capacitance checker. It comes on a few volt meters. It will have the Mfd symbol or uf all you have to do is set the meter to capacitance and put both leads onto the capacitor (with nothing else attached) and the meter will increase up to to a near stopping point within 10% of the rating of 35uf. so if it reads 32-38 its good. New capacitors are cheap and available at any HVAC supply store. They should have the exact one you need or guide you to which one is an acceptable substitute just bring the old one with you. I believe the recomendation is within 10-15% so 40uf would be ok. but check with the store just to be sure. It will run $7-22 depending where you go.
