I bought a new flyback transformer for a RCA D52W19 TV, but it came with no HV wire. How do you connect to it? Or maybe I was had?
How do you attached the wire to the transformer? I slid it down into the top part of the transformer, but how do I know it made a good connection? The HV wire was soldered and potted into the old transformer.
Posted on Jul 24, 2008
  • 2,326 Answers
This transformer does not come with the HV lead, you will need to use the one that is there on the old FBT. Unplug the TV for about 30 minutes to allow it to drain any voltage that might still be in the capacitors.
Remember SAFETY comes first.
Good Luck.
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
Burn spot and sparks
is it a off white block with a pink wire set going to the 3 picture tubes?then it is the high voltage called a flyback transformer.
the output is 28000 volts.you have to discharge the tubes before replacing the anode caps which are connected to the flyback.
this is a severe shock danger.
do not attempt this without the service manual ,about 35 dollars from rca.
May 28, 2009 | RCA D52W19 52" Rear Projection Television
Removing the HV Wires from Flyback on RCA TV D52W19/
You really dont need it its only a wire.sliice and reconnect.
Feb 18, 2009 | RCA D52W19 52" Rear Projection Television
D52W19 Screen Flicker
Go back to FBT check and make sure your high voltage wirer is in good.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
Tv stop working
That model is famous for bad flyback which is what I believe is your problem as well. The flyback is the HV transformer.
Apr 11, 2008 | RCA D52W19 52" Rear Projection Television
My RCA TV 52inch HDTV makes a sizzlin sound and shuts off by itself
Your HV transformer (flyback) or HV block is cracked those are common problems with that model. If you want to do it your self heres a link that can help you. go to their site and leave an email about your symptoms.
http://servicemanuals.vstore.ca/
Apr 03, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flyback Transformer Replacment guide
The picture tube can hold a charge.with a jumper connect one end to the ground wire around the picture tub. attach the other end to a screw driver and push it under the red cap on the picture tub. that will discharge it.. Remove the transformer from the board by disordering all connections. Insert the new fly and solder. from the old transformer follow the two leads on the side to the screen board at the picture tube. one at a time connect the new transformer leads to the socket and board. part number for the FBT 259296 $50.39 from www.the parts store
Mar 21, 2008 | Televison & Video
RCA HD52w66
solder around flyback pins ,also these sets are having major problems with flyback transfromers/high voltage tripplers.let know how you come out after soldering HV transfromer.
Jan 26, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
221 people viewed this question
Top Televison & Video Experts
