posted by jmolina on Jul 24, 2008
Projector is in standby mode (green light blinking). Push power on the unit or on the remote, the green light stops blinking and stays on for about 3 seconds then goes back to standby blinking. No fan noise, no lamp light, no other noise of any kind. Also, none of the other led's light. Lamp looks to be good. Any help is appreciated. Thanks.
Comment by jmolina, posted on Jul 25, 2008
Sent in the same description to Optoma tech support. They mentioned it could be the ballast or lamp driver. I took the unit apart yesterday and found a bulging capacitor on the power board. Will replace and see if that helps.
Comment by jmolina, posted on Aug 05, 2008
Solution!
That was it! Bad 10v, 3200uF capacitor on the power board. Replaced it and the projector is alive and well again!
Suggest a new solution for this problem
Post a New problem for Optoma EP719 XGA DLP PROJECTOR 2000L
Email this problem
Email this problem
Can you Help with these Multimedia Projectors problems?
Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1...
Optoma 719 dark circle in...
It began as a smaller spot, but... Answer This...
lamp comes on then goes off
lamp comes on, then goes off... Answer This...
Optoma DLP model DX605R...
I use my projector for... Answer This...
I have only used my
I have only used my
I have only used my optima... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
