Dvd/cd drawer will not open - Computers & Internet
  • ayin22 Dec 19, 2008
    I just bought a Powermac G5, and cannot find any mechanical or non-mechanical way to open the CD/DVD drive so I can put new software onto my computer. I thought Apple was simpler??
    Problem Solver:
  • 17 Answers
Hi overeater,
With your system turned OFF and unplugged, look at the front of the drive, you will see a tiny hole to one side. Open up a paperclip, insert it into this hole and push gently. The door will pop open. Pull gently the rest of the way.
If this has been the first occurance of this, try just turning your system back on and allow the drawer to close on its own. Then try opening it the correct way again.
If the door fails to open again - most likely the belt for the drive is bad. DVD/CD drives are fairly inexpensive these days and would probably be best to replace it.
Posted on Jul 24, 2008
On the G4's if you press the mouse on the right side - holding it down while the computer is booting up, it will open the rom drive.
Posted on Nov 08, 2008
Dvd or cd are not open
I think you are saying that the CD/DVD drive drawer will not open?
Most drives have a tiny hole above the drawer. You need to straighten out a paper clip ,then poke it into the hole. This should release the drawer catch and you can open it by gently pulling. It may be jammed as a disk was not properly seated inside.
Check on My Computer that your computer recognises the CD/DVD player is there.
Mar 03, 2014 | Panasonic SC-PM39D System
MHC-RG270 cd draw won't open
cd drawers often jam.
In the cd/dvd drawer you will see a small hole. Use a blunt pin or a straightened-out paper clip, insert it into the small hole and gently press. The drawer should then click open.
Try cleaning the plastic drive teeth/mechanism with a light drop of oil. Press the drawer button and it should then close. Press it again to see if the drawer opens as per normal.
If your cd drive plays a dvd as per normal but doesn't open when the button is pressed, continue using a blunt pin/paperclip. If the plastic open-close mechanism is worn or damaged there's very little you can do about it expect replace the entire drive.
Feb 01, 2014 | BenQ FP91G+ 19" LCD Monitor
Dvd drawer locked and dvd wont play
Is it a store purchased dvd movie or is it a dvd that someone made and gave to you? Computers sometimes have problems reading cd's and dvd's that someone made. Try a store purchased movie dvd or music cd.
When you press the button on the dvd drawer it does not eject? Clcik Start/My Computer then Right Click on the DvD Drive and click Eject.
If it still does not open, take a Gem Clip (Paper Clip) and straighten it out as much as possible. Then look at the DvD Drawer and you will see a tiny hole that you can insert the Gem Clip (Paper Clip) into. Push the Gem Clip (Paper Clip) while you press the button on the Dvd Drawer and drawer will open. Don't worry about damaging or breaking something, that is why that tiny hole is there.
May 16, 2012 | Computers & Internet
This is a dvd recorder for a tv the door door to yhe dvd will not open
sounds like something has jammed in the drawer track
on the front of the drive is a very small hole
that is the manual open override
use a paperclip and push it into the hole as far as needed until the drawer opens
then slowly open the drawer by hand
look on both sides of the drawer to make sure there is no dirt or other foreign matter in the tracks where the drawer opens
Dec 16, 2010 | Lite On LiteOn 16X Dual Layer DVD...
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
Cd drawer will not open
To open your cd drawer.On the front of your cd you will see a small pin hole,straighten out a strong paperclip and push the end through the hole,and this will release the catch and open the tray. Push hard as the catch will be quite stiff. Hope this helps you.
Regards Bill
Mar 14, 2010 | QPS Que! USB 2.0 Drive CD-RW Burner
Cannot get cd drawer to open. LCD says load, but
take the top cover off and have a look at the dvd,which has probably come off the tray. it is jammed for some reason
Aug 18, 2009 | Toshiba SD-K760 DVD Player
DVD had a jammed disc. Got it out but drawer stays open
You broke it. Spend $30 to buy a new CD/DVD reader/writer.
Dec 21, 2008 | Compaq (224130-001) Internal 4x CD-ROM...
Dell Modem CD Drawer Won't Open
Yes. There should be a very small hole on the front of the CD/DVD drawer. Insert a straightened paper clip into this hole until you feel it push a button, and this should manually release the drawer.
Nov 05, 2008 | Computers & Internet
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Computers & Internet Logo
386 people viewed this question
David Payne
David Payne
