Question about Uniden Cordless Phone
I want to know how to link my 2 cordless phones to my base they only say unavailable
Read up above
  • lorimkt Oct 24, 2008
    The phone is not the problem, it's the connection! What's up with that!? I don't want to take it back...I have two main bases and we've tried it on both to no available. This phone sucks.
Possible Solution: Try calling your phone, put the other handsets on the main base while it is ringing. I did this and my other handsets started to ring and work.
Posted on Oct 18, 2008
I called ge directly in california and they went through the same steps that are in the manual and it didn't work the last step might prove usefull to some of you. You have to reset your phone. First unplug the power cord then unplug the phone cord. Leave them unplugged for 15 minutes. Then reverse the process of plugging them in. That will reset your phone and that may work for you. It didn't work for me so they told me to buy a new phone. So I did. Hopefully that helps some of you.
Posted on Jul 25, 2008
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
Handsets display "unavailable"
have you tried to charge all phones then placing them in the base one at a time to reset them? I know when the phone cord or the power is of my base my other units do not work..
Aug 23, 2009 | Uniden Cordless Phone
No dial tone both units
You have almost left no stone unturned. It is either a bad base station or a bad cord between the base and the jack. Try a new cord.
Jun 26, 2009 | GE 25840GE3 Cordless Phone
Uniden dect 6.0 display reads searching
Hi there, try this. Press and hold th eend key on one of the handsets, while holding the end key, press and hold the # key. After 3 or 4 seconds tha thandset should beep and read deregister Handset and underneath that "Base Unavailible". Select base aunavailible and confirm. Then tha thandset should read "Handset not registered, place handset on base" Once you place the handset in the bace cralde it should register in 5 - 10 seconds or so. then you should be good to go.
Jun 23, 2009 | Uniden Cordless Phone EXAI985
Uniden 2.4 GHz cordless phone won't register to base
Same happened to me. Unplug the base from power and the phone line for 30 minutes. Same for the handsets - all. Take out the batteries. Retry. After it says 'registration failed'. Leave it in the cradle. Several minutes later it found itself.
Mar 10, 2009 | Uniden 2.4 GHz Cordless Phone System
My cordless says unavailable
I put the phone on the master handset (I registered it)
Jun 20, 2008 | Uniden Cordless Phone
Moved and keep getting unavailable on my phone when I press talk
There has been a power base failure, in which case you must place all handsets on the main base cradle for 20 seconds to re-register.
Mar 19, 2008 | Uniden Cordless Phone
Ge cordless phone station 2 shows unavailable
You have to register the hand set in the main base. Place each handset in the base for 15 seconds minimum. It will change form unavailable to Ready when it grabs the signal from the base. If the power goes out, you will have to re-register each hand set in the base before you use them again.
Jan 14, 2008 | GE 25932 Twin Cordless Phone
New dual phone "Unavailable"
read the manual,you have to put code from 1st base phone,
i do not remember the code,
Jan 01, 2008 | GE 25932 Cordless Phone
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
Dave Ellis
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
