Question about Brother Office Equipment & Supplies
I keep getting error message when i try to install my mfc665cw all in one printer usb device not recognized has malfunctioned windows doesnt recognized
    Guru:
  • 1,049 Answers
With any unresponsive USB devices in XP it is always a good idea to try removing the device first with uninstall, plug it into a different USB port, and then reinstall the setup software. (Preferrably using a version from the vendors home-site instead of the original CD.)
This will do two things:
  1. It will make sure that you are running the most up-to-date version of the installation software and driver.
  2. It will keep Windows from trying to "put back" the same settings that are causing you issues.
Posted on Jul 24, 2008
  • NA NA
    NA NA Jul 25, 2008
    Was this helpful?
Printer not being recognized by computer
Sir/Madam
1. Is the printer turned on?
Make sure the printer is turned on.
Make sure the power cord is securely plugged into the electrical outlet.
Test the power by plugging in the power cord of another electrical appliance to an electrical outlet and turn it on. If the power to the other electrical appliance comes on, the printer may be considered to be faulty.
If this product is recognized:
Close this page to return to the installation window.
If this product is not recognized:
Proceed to the next step.
2. Are your computer and the printer correctly connected?
Make sure the USB cable is securely connected to the printer and to your computer and check that the USB cable is not damaged nor badly crimped.
The printer will not be recognized during the driver installation if connected to a printer switch or the printer buffer. If this is the case, try to directly connect the printer to your computer using the USB cable.
If you are connecting the printer to your computer via a USB hub, connect the printer to the first-tier hub from your computer. If the printer driver is still not recognized on your computer, try to directly connect the printer to your computer without the USB hub.
If you are connecting the printer to your computer via a USB hub, make sure the USB hub device is recognized by your computer.
3. Does your computer provide USB or IEEE 1394 support?
If Still Your Problem Is not solved Then Click On Below URL
http://files.support.epson.com/htmldocs/r1800_/r1800_rf/dset_1.htm
Or
Still You have problem Then please Follow Us On HP Printer Support
Jan 08, 2014 | HP P4515n LaserJet Printer
Windows Vista does not recognized the Brother HL-2240.
hi Markaz.
you can try is to open Device Manager, expand USB Serial Bus Controllers, right-click on USB Root Hub and then click on Properties. Click on the Power Management tab and uncheck the Allow the computer to turn off this device to save power box.
or read up more at this link.
How to Fix USB Device Not Recognized in Windows
What do I do if my USB device is not recognized? Method 4: Reinstall USB controllers.
  1. Select Start, then type device manager in the Search box, and then select Device Manager.
  2. Expand Universal Serial Bus controllers. Press and hold (or right-click) a device and select Uninstall. ...
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Error: "USB Device not recognized" when you try to access a USB ...
https://support.microsoft.com/.../error-usb-device-not-recognized-when-you-try-to-acces... Search for: What do I do if my USB device is not recognized?
or this link.
Windows does not recognize the USB device Google Search
Dec 02, 2017 | Brother HL-2040 Laser Printer
Replacing HP 7580 all in one scanner fax with HP 7590 all in one scanner fax. I did not have install CD for 7590 so downloaded drivers from HP site. Error message keeps saying that does not recognize...
first Step - Try another USB Cable.. If this does not solve, try the steps below.
Power off the Printer
Disconnect the USB Cable from Printer to PC ( from PC )
Disconnect the power cord of printer frmo wall outlet
Power off the PC
Disconnect the Power cable from back of PC and from wall outlet as well
wait for 10 minutes
Connect the PC power cables to PC and Turn on the PC
When you login to your Desktop, Turn on the Printer
Connect the Cable,
It should get recognised.
Regards,
Ron
Feb 22, 2011 | HP Computers & Internet
My 17 " Targus chill
Ignore the messages -- you connect it to draw electrical power through the USB port, and that's all you need. It's not like some USB-devices (printers, scanners, et cetera) where getting power to the device is only "half" of the solution.
Oct 29, 2010 | Computers & Internet
Turn off CPU, Unplug Power cable, And all usb devices, let it sit for about 20mins. Plug it all back in. Turn on the CPU! Also make sure if your device requires "DRIVERS" or if you have a CD download and install that before anything.
Dec 01, 2008 | i.Trek M5 GPS Receiver
Having trouble installing HP Photosmart All in One Printer. Model C5280. Near the end of installation it ask's for printer to be connected via USB cable. Msg comes up on screen 'USB Device not recognized'...
Dear Sir:
It seems that the printer has gone bad because when you get this message 'USB Device not recognized' it means that the usb device connected to the computer is defective however I would suggest you to connect this device to another computer and if you are getting the same error with the other computer.
Please contact hp support they should be able to help you with this.
Please feel free to get back to me If you need any further assistance.
Regards
Mohammed.
Mohammed.feroz.ali@gmail.com
Jul 19, 2008 | HP Computers & Internet
Computer cannot detect printer
ok..
remove all software from computer for printer
go to www.canon.com and get new drivers by model and operating system
re install
try it again.
Jun 11, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Urgently help me printer not recognized.. hyd
hi!good pm...hope this will help...
try to check the USB cable connected to your cpu & printer,see if its inserted properly...or try to plug the USB cable to other USB socket...if this does solve your problem,get another USB cable & try it...
Feb 08, 2008 | HP DeskJet 3940 InkJet Photo Printer
Hp laserjet 1020 ( usb device not recognized )!?
I'm not sure, but I think I understand that you're connecting using a USB hub? If so, try connecting it directly to a USB port. Many times an unpowered USB hub does not supply enough power to run a laser printer. Unhook the printer. Go to Printers and Faxes - delete the printer. Hook up directly to a USB port. Let the computer re-install the printer. Let me know Ed
May 05, 2007 | HP LaserJet 1020 Printer
157 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
