Question about Gateway Computers & Internet
Computer not showing anything! I ts probably in the Bios setting be cause I set the settings to optimize defaults .
  • Femi Omojogberun May 11, 2010
    Does your computer boot up to windows prior the time you optimize defaults? Now it doesnt show u nothing even POST test? Give clear cut information to help u out.
We got cut off now im screwed
Posted on Jul 24, 2008
How can i fix my computer it does not continue
you write drives i suppose you mean HDDs 1 or 2 maybe 3.
if set optimal defaults in BIOS.BIOS can change drive to boot from
windows is at one of them.
Apr 23, 2013 | Computers & Internet
What is the difference between fail-safe defaults and optimized defaults in bios
failsafe defaults are settings that aren't necessarily the best settings for the computer but should work with any operating system, optimized defaults utilize the hardware to it's optimum capability
May 04, 2012 | Computers & Internet
When my computer ons ,it shows that there is a microcode error and that i need to update my bios.because of that i can't make my system to boot.i am confused and i need your help please.thx
First try going into your BIOS and set it to "Optimal Defaults". To get into the BIOS when your computer first boots up keep pressing delete as its booting until you get to the bios screen and look for "Load Optimal Defaults" or something similar and then save and exit. Then tell me if that helped.
Feb 24, 2011 | Compaq Evo D500 PC Desktop
Why my pc show IDE #0 ERROR?
this error is shown cause the hard disk ide connection is not proper or defectuous ..check the HDD to see if it is functional ..and also check it to be inserted proper..
Also ..go to BIOS settings by pressing the F2 on start ..and in there choose the "optimal factory defaults" and save the changes with F10 after ...
If any strange setting had been done in Bios and caused this error ..this will bring it back to the factory settings and will make it work ..
Dec 21, 2010 | Computers & Internet
My kid pressed f9 and the the mouse got frozen and i dont know what to do
first if the mouse did not get back after restart means that it is probably disabled...(Im not sure if it is from F9) ...if we talk about an external mouse the issue probably got solved after the restart ..if we are talking about the touch probably need a different approach ....Go to bios setting by pressing F2 on start if it is a laptop ..and del key if it is a desktop the Bios settings look for the optimal factory defaults ..and activate it by selecting and pressing ok (enter ) than save the changes with F10 and enter ..This action will reset all bios settings including any disabling forcing the computer to recognize again all devices..
If it is an external mouse..and USB probably need to run the driver disk again ..cause the issue may be from a defective driver ....
Jun 25, 2010 | Toshiba Satellite M35X-S161 Notebook
Key of perfect optimizer i want this key
I'm not sure that I understood what you are talking about but if you are talking about the optimal factory defaults ..these have to be set from the bios..and the key is different from one bios edition to the other ..for some models the key is F7 for most it is F9 ..but ..o the bottom of the bios setting page is written the key for the optimal factory defaults...just navigate from the first page if you do not see it ..and it will be in the list for commands..near the one that saves the settings ...
so all you have to do is see what is the key ..(probably F9 ) after you press it ..confirm with yes (enter ) and to save all changes and get out from Bios press F110 and enter ..after that all the settings will be optimized..and the disabled devices that in default have to be enabled will activate themselves..
May 20, 2010 | Computers & Internet
Bios settings?
these settings are related for boot up troubleshooting....system need startup point that is called boot up point.. Now there is sequence for search for boot up device that contain boot up point These device consist of floppy drive, hard drive, cd rom, usb drive and try to set your boot device priority with hard drive as first device....this will solve your boot up reply back
Oct 02, 2009 | Computers & Internet
Bios setting problem?
Optimal Defaults and Fail Safe Defaults are two different sets of values. If you set one after the other the second would have replaced the first. Try setting back to optimal again.
If you still see errors relating to the Ethernet adapter find the Ethernet adapter in your BIOS settings and set it to Auto. If you still see errors try all of the available Ethernet settings.
Hope this helps you get your computer running again.
Oct 01, 2009 | Computers & Internet
I have no video output on my desktop, a gateway media center GT5034. all the lights blink, showing haddrive activity. I have tried to different monitor and another video card.
Try removing your RAM cards leaving only 1 at a time in a try to boot until you figure out which RAM card is causing it. Sometimes bad RAM can cause issues like this.
If that doesn't work, try unplugging the power from the tower, and then open up the case and remove the CMOS battery which is on the main board (motherboard). It's a little flat round battery. Leave it out for 30 seconds or so, then put it back in, close your case, and try to boot up. What this does is clears the CMOS so it will be set to default bios settings. After you do this, it may show a picture on the screen, and then you can go back into your bios settings and set anything you need to back up. Or you can just load "Optimized Defaults" and then press F10 to save the settings and reboot.
I hope this helps. If not, let me know and I'd be glad to further assist you.
Best Regards,
Jul 21, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
Should cooling fan on my acer laptop 5520 stop at times is it thermostatically controlled
all computers have this kinda operationb is controlled from the bios settings and its not recommended...cause at some point it might get too hot and burn ...try to open it and pressing del to get into bios...after that look for something that says anything about factory settings or optimal default settings ... usually at most computers ...its set by pressing F9 and after that f10 to save settings ...but Im not sure for your model...
Jun 06, 2009 | Computers & Internet
Computers & Internet Logo
18 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
