Question about Haier HTE16WAA Top Freezer Refrigerator
Need parts for trays
Supports that hold up frui and vegtable trays broken
I have a hp color laser Jet cp2025. The small plastic has broken off the side of tray 1 that hold the tray in place. I cannot find a part number to replace. Please advise
Hello Andy,
The tray 1 is part of the front door assembly. The part number is RM1-4848 and it is available from several web sites.
Sep 12, 2013 | HP Laserjet Cp2025n Printer
Trio (795) icemaker tray stuck in the dump positon water on door works
First we need to get the correct model number. It should be on a tag somewhere on or in your refrigerator. Mine is on the right lower side and can only be seen when moving the vegtable drawer.
Then I can look up the part you need and give you an idea of the cost of the part and how hard it is to replace.
Jun 16, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My vegtable tray center bar has snapped from the glass -- I need to get it fixed, or replaced
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
May 01, 2011 | Viking VCSB483 Side by Side Refrigerator
The sorter tray..where the copies are deposited...comes detached from the copier...it seems to be broken, you have to hold it in place or the normal vibrations of the copier causes it to detach..where can...
I belive that the part that you need is called Holding Tray Assembly and the part number is FG5-8666-000 and I think that you can find it at any Canon Partener.
Nov 15, 2010 | Canon NP 6035 Copier
The hood latch cable is broken or disconnected, how do I get the hood open to repair
if you can't pull cable under dash, need to access from under front of car. Try to pull cable or remove 2 screws holding latch on.
Item Part Number Description 1 — LH Shock Tower 2 10732 Battery Tray 3 16916 Hood Latch Control Handle and Cable 4 04320 Instrument Panel 5 — Screw—Release Handle Mounting (2 Req'd) (Part of 16B975) 6 16700 Hood Latch 7 — Radiator Support 8 N802850-S307 Screw and Washer—Latch Mounting (2 Req'd)
Mar 30, 2009 | 1997 Lincoln Continental
Plastic clip holder to hold dishwasher tray is broken
If you are handy, contact an appliance parts store that sells retail. You should find them in the yellow pages. Brand and model number will be needed usually on the inside edge of the door.
If you are unsure, Look in Repair and Service link at Fixya.com for a repair service in your area.
Good Luck,
Dec 05, 2008 | Home
Top Tray clips on diswasher broken
I have the same problem and there is an inherent design flaw. You can normally buyt these at most outlets, however you can buy more than 4 to support the tray, or I have cut a small diameter aluminium tube (1/4" diameter) and threaded it through the tray from the side and into the sliding rails. It is not an ideal solution, but will last a lot longer than the silly grey wheels! Doi two bits ( one at the back and one at the front.) You have to play around a bit to get the drawer to move in and out, but it is much stronger than before. Good luck Charles in Australia
Aug 17, 2008 | Westinghouse 24 in. MDP531 RF...
Haier HTE16WAA Top Freezer Refrigerator Logo
15 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
doggzzz
Level 1 Expert
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
