Question about Dryers
Has had pampers put in and plactic is melted in the tub over and over again
    President:
  • 1,779 Answers
Oh boy, that sounds like a mess. Never dealt with that problem, but here's an idea. Run dryer on high heat setting for a short time, wear gloves and long sleeves for protection and see if you can clean out the plastic while it's still 'gooey'. Use clean rags to wipe it out. You would probably have to do it several times. DON'T use any kind of cleaners, as they may explode or cause a fire from the heat. Good luck! Countrycurt0
Posted on Jul 25, 2008
Complaint with the poor quality of Pampers Nappies
not a fixya site problem
get the company web page up, use the contact section and make you complaint directly to them
Jul 07, 2017 | The Office Equipment & Supplies
How do I contact the manufacturer of this unidentified appliance?
here again with no make UNIDENTIFIED stays just that . mystery machines
Sep 16, 2015 | Crock Pots & Slow Cookers
I want to re make my pampers account, because I mistakenly put myself down as a male, but I am not a boy, I am a girl thank you
Not sure about Pampers but most online accounts have facility to edit profiles and make changes to the account or to delete an account altogether.
If in doubt I suggest you check with customer service because your details could remain with them for a considerable time so closing an account and then opening a new one straight away could cause trouble unless you use a different username, password and often email address too.
Jun 26, 2015 | Computers & Internet
Is this the most absorbant of all diapers.
We liked parents choice brand from Walmart for our 3 sons who leaked through everything else. I hope this helps.
Apr 26, 2015 | Pampers Baby Care
Arcing
What is the wattage of the microwave oven? This device is rated for 800 watts or less. Tupperware Contact Us About Us
Dec 13, 2017 | Frigidaire Over-the-Range Microwave
How to fix a dripping Delta Monitor shower controls?
Turn off the water, disassemble the control and replace all rubber pieces and damaged plactic, if any.
Sep 21, 2010 | Delta Monitor 13 Series Chrome Trim...
2006 Chevy Equinox Smoke emitting from the steering column with smell of burnt plastic. I have popped off the harness cover but not been able to deduct source of smell or any damaged...
Turn signal switch is common issue, the plactic melts when the contacts overheat. look for discolored or malformed plastic, near wires and contacts.
Sep 21, 2010 | Chevrolet Equinox Cars & Trucks
My break lights are constantly going bad on my 240 volvo. From the fuses to the sockets to the little white box in the back where the wiring hooks up to the lights having a melt. Why can't I get my breaks...
When the plactic melts, the metal has overheated too much and cannot be restored. Cut out the old sockets, and enough of the wire to get un heat damaged wire. and splice in the new sockets. DO not use the old bulbs, get new ones, or the issue can continue.
Sep 17, 2010 | 1992 Volvo 240
We are having issues again with the 2003 tdi automatic. If you need to put your foot into the paddle and are only in first gear it will go into the starvations mode. You then have to pull over and shut it...
Sounds like it is starving for fuel, try replacing the fuel filter too, for gods sake do not by pass filters for too long just to test is fine. good luck
Nov 14, 2009 | 2003 Volkswagen Jetta TDI
A penny fell underneath the agitator & went underneath inside the tub
remove 2 rubber plugs on each side of lid remove the screws underneath lift top up remove the plactic ring around tub top by pulling up on clips along top edge remove the spring on left attached to ring lift ring off remove agitator again lift inner tub up and out ..when reinstalling inner tub be sure it drops completely in so the center gear drops in place
Sep 07, 2008 | Fisher Paykel EcoSmart GWL15
Dryers Logo
37 people viewed this question
Top Dryers Experts
