Question about HP DesignJet 450c InkJet Printer
ERROR LIGHTS My data light and my cartridge light are a solid orange. I can't cancel or by pass them. Tried replacing all cartidges. Any one have any ideas?
  • cherforth Aug 06, 2008
    Ya, I tried that. Not helpful
I have a 450 c plotter. The cartridge, data amd media lights are flashing orange
Posted on Mar 27, 2009
    Problem Solver:
  • 7 Answers
Is your ready light on as well? If so this may indicate that the "mark encoder" is not detected.The mark encoder is the white plastic piece on the left end of the large black roller that the paper feeds around.If the encoder is very dirty,then cleaning may help.If not, carriage usually has to be replacved, I have heard of some that paint over the mark encoder with white out before replacing the carriage. Don't think I would try it but....Hope this helps.
Posted on Aug 28, 2008
Get the manual for the hp450c and check the error codes section. This will tell you were your problem lies in the plotter .
Posted on Aug 06, 2008
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Trying to remove color cartidge error if not using color bliinking orange light
Unfortunately no, Printers require both cartridges to be installed and operational to enable the printer even if you are only printing black text. No way to bypass this "feature".
Feb 15, 2013 | HP DeskJet 950c InkJet Printer
I bought a used HP Design Jet 450 C...But its showing the cartridge and data solid orange light and ready light is constantly green. I brought a new black cartridge, the printer takes in the paper and...
I think the problem is not the computer. You shoud check the plotter by running the test print without the computer. When plotter's power is on, press Setup and Cancel keys simultaneously. If it does not print, then the plotter need repair.
According to your descriptions, there is System Error Code shown on your control panel. when the lights on for Ready+Cartridges+Data (DKL), it may have 9 possible causes referred by Service Manual page 2-7. You can check all these 9 items to see which one causes the problem.
Dec 17, 2010 | HP DesignJet 450c InkJet Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Cartridge seems to move smoothly. Just get the
    There could be 2 reason for this error. You can either reset the error or try and clean the printer from inside which might be causing the problem. Below are the 2 steps:
    STEP 1: Clean the printer from inside
    1. Opened the cover and checked the front right of the printer near the waste ink pads
    2. Carefully turn the cogs to move the ink cleaning mechanism
    3. There might be a load of paper jam debris blocking the mechanism from reaching its port
    4. Carefully cleaning this out and putting the printer back together
    STEP 2: Reset the error
    1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
    3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
    4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
    5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
    6) Power off then back on and test.
    Apr 26, 2009 | Canon PIXMA iP90 Mobile Printer
    Catridge light and Data aresolid orange when machine turned on
    This is a problem, sorry to say. The Mark Encoder is not being detected. In laymans terms this means that you need a new carrage. Part Number is C4713-60039. You also need to check on the condition of your belt at the same time. Is there somebody in your area that can do the work or are you capable ?
    Dave
    Apr 20, 2009 | HP DesignJet 450c InkJet Printer
    I get a message error that ink cartridge is not well installed
    Remove all the cartridges then back again installed..if the orange light is always blinking.long press the cancel botton til the green light is steady..ok..
    Jan 03, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
    Ip4000 5 flashing orange lights
    5 orange flashes indicates a problem with the print head. you could try carefully removing the print head (the thing holding the print cartridges) and replacing it. turning it off/on. make sure the print cartidges are ok. If still no good you might need to get it serviced?
    Aug 24, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
    HP DesignJet 450c InkJet Printer Logo
    705 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
