Question about Cameras
I have an 8mm high digital camcorder tape which got tangled in the camcorder. when i wound the tape back in the case and returned it to the camcorder it would only play a high pitched sound with no picture! Is it ruined or can the film i recorded on the tape be cleaned and rectified?
    Scholar:
  • 135 Answers
I've had to fix this problem several times. You need to open the 8mm cassette, and manually rewind to where the tape got twisted around. Then untwist it, and manually wind the tape back on the reels. and then put the cassette back together. If the tape isn't torn you should be fine. There might be creases in the tape- but they will only give you a slight picture glitch or drop out. You need to run a head cleaning tape through your camcorder before you try taping again. It might hose up the next tape if you don't.
Posted on Jul 28, 2008
Sony Handycam CCD-TR517 8mm Analog Camcorder
you can do that with EASYCAP usb2, a camcorder video capture card card " USB Convert VHS Tapes CAMCORDER to DVD Capture 0" , on ebay from wanghaostore. 10$. works perfectly, useful to digitalize VHS tapes too.
Jul 22, 2010 | Sony Handycam CCD-TR517 Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Nov 01, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony DCR-TRV145E Digital 8 camcorder - won't play or record.
Fortunately they are still making 8mm camcorders usually running less the $200 to replace. It could be more cost effective to get a new model for that price as well. I couldn't record on my Sony 8mm camcorder anymore after five years of use and over 100 tapes that I had recorded. It's plays back but that's about it.
Aug 19, 2008 | Sony DCR-TRV285E Digital-8 Digital...
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Jan 05, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
8mm/Hi8/Digital 8
As this was quite some time ago, you probably already have your solution, but I just ran across this. Just in case you can use any other 8mm camcorder or deck if you can find one. Also if you still had it I would like to buy the Instruction manual from that old Canon ES780. Please write me back at bpgray@verizon.net if you have it. Thanks.
Dec 14, 2007 | Canon ES870 8mm Analog Camcorder
Tape stuck in camcorder
Turn off
Take battery out
plug in to power
turn on
Tape shoudl pop out.
it worked for me!
Jul 31, 2007 | Sony 8mm Stantard Grade 120 Minute...
Sony DCR-HC42 makes a buzzing sound
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
Tape compatibility question.
Yes. Hi8 camcorders are manufactured to work with 8mm or Hi8 tapes. The difference is the quality of the tape. 8mm tapes will provide about 270 lines of resolution where a Hi8 tape will provide up to 400. For better quality recordings, you'll want to use Hi8 tapes.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Cameras Logo
91 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
