Question about NEC VT460 Multimedia Projector
Its all the time
Its constant flash,flash,flash, flash
  • 10,594 Answers
Is there any interval, break between flash?
Posted on Jul 25, 2008
My Samsung LE32N7 does not come on. The blue light under the screen constantly flashes without the tv coming on.
Hi, maybe the TV controller board is blocked, you can reset it, by disconnecting power cable from outlet for about 5 minutes, if that doesn't work, possibly and internal board or component must be repaired of replaced, in such case it's better to contact an authorized Samsung service center or technician to check your TV.
Nov 07, 2017 | Televison & Video
Machine starts then program end light flashes constantly and has done nothing?
I had similar problem and Eventually replaced motor brushes which solved the problem
Feb 26, 2012 | Hotpoint WMA11 Front Load Washer
My television turned itself off and will not turn back on again, the blue light is constantly flashing.
Hi
How many times does the light flash... i.e. flash flash flash flash flash...pause, then repeats?
If you include the make and model of the TV in your reply this would be helpful.
Regards,
HillElectronix
Aug 04, 2011 | Televison & Video
Constant paper jam..no paper have restarted several times
Got the same problem here! Did you find a solution?
Oct 24, 2009 | Office Equipment & Supplies
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
Clean LED constantly flashes,only function is drain
If it's a Whirlpool, and flashes seven times, then you have a heater circuit problem. You would need to diagnose which component is at fault
Affordable Appliance Reapir
Lake Forest, CA. 92630
Aug 23, 2009 | Dishwashers
Flash
Just hit the flash mode button until the get the lightning bolt symbol meaning constant flash. I use this all the time on the same camera for a backlit subject when I need a fill flash
Mike
Jan 06, 2008 | Olympus Camedia C-2040 Zoom Digital Camera
The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Nov 01, 2007 | Washing Machines
NEC VT460 Multimedia Projector Logo
59 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
