Math TITLE-AREA OF TRAPEZIUM . MATERIAL REQUIRED-DRAWIND SHEETS,RULER,PENCIL,A PAIR OFSCISSORS,COLOURED PENS FEVISTICK & TRACING PAPER. . PROCEDURE-1) DRAW ATRAPEZIUM ABCD SUCH THAT AB||C, AB=x,DC=y & PERPENDICULAR DISTANCE BETWEEN AB & CD=L ON DRAWING SHEET . 2). TEACE OUT THE TRAPRZIUM ABCD ON TRACING PAPER. 3). CUT OUT THE REPLICA OF TRAPEZIUM ABCD FROM THE TRACING PAPER & PASTE IT WITH TRAPEZIUM ABCD. OBSERVATION- AREA OF ||gm= 2 AREA OF TRAPEZIUM (X+Y)xL = 2 AREA OF TRAPEZIUM
Quadretic Equataion
Posted on Aug 27, 2008
X+1/x=2cosa let find the value of 13x+12/x
Posted on Aug 08, 2008
How do you use the Apple Pen with the iPad pro
hi marilyn.
The first time you use your Apple Pencil, take off its cap and plug it into the Lightning connector on your iPad Pro. When you see the Pair button, tap it. After you pair yourApple Pencil, it will stay paired until you restart your iPad, turn on airplane mode, or pair with another iPad Pro.19 Sep 2017
Use Apple Pencil with iPad Pro - Apple Support.
How do you use the Apple Pen with the iPad pro Google Search
Nov 01, 2017 | Apple Tablets & eReaders
My cannon pixma mx360 won't print. The paper gets jammed and it won't print.
Look for a fragment of paper or other foreign object in the paper path. Often feeding a sheet of thin card back through the paper path will push any offending object out. May include insects, paper clips, leaves, rubber bands (the worst), pens and pencils, and of course torn or scrunched paper.
Jan 30, 2017 | Canon PIXMA Office Equipment & Supplies
1904 sq feet how do I convert this to linear feet for roofing
I have done tons of roofing and we always use square feet .length X width= sq ft .like 50 ft long by16 =800 then double to get both sides of roof is 1600 sq ft
Feb 12, 2015 | Cars & Trucks
Paper jam
Hi Ruth,
This should help you fix the issue.
Remove Jammed Paper
If business card sized paper loaded sideways is jammed:
1. Power the printer off.
2. Open the top cover.
3. Remove the jammed paper with your hands.
Note: Be careful not dirty your hands. Do not use tweezers or other metal instruments to remove the jammed paper or printer damage may occur.
4. Close the top cover and power on the printer
5. Load the papr correctly in portrait orientation to resume printing.
remove foreign objects
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once.
The images below show the iP2200 model.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. If there is any foreign material, remove it by hand or with tweezers.
3. Open the front cover and confirm that there is not any foreign material in the printer. If there is any foreign material, remove it by hand or with tweezers.
Note: Avoid touching inner parts.
4. Power the printer on and confirm that the printer operate normally.
Use a flashlight to find any possible jam.
Regards,Suhail
May 19, 2012 | Canon iP2600 series
What is the formula for getting the surface area of a trapezoidal prism?
Surface area of any prism is the sum of the areas of the sides
A trapezium is A = h(a + b)/2
h is the perpendicular height, a and b are the parallel sides
Aug 10, 2011 | Encore Math Advantage Algebra II and...
How do i take the back off a canon pixma mp240 to reach inside it to pull out sticky tack that has gotten stuck in the paper feeder?
Welcome to FixYa!
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
3. Open the scanning unit (printer cover) and confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Note : After confirming that the scanning unit support is fixed into position, release your hands.
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
4. Close the scanning unit (printer cover).
5. Power the printer on and confirm that the printer operates normally.
Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
Rates and comments are appreciated.
Thank you for using FixYa.
Jas
Mar 02, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Paper jambs in the feed. The right side seems to pull down first then just jambs up.
Solution: Remove foreign objects from Rear Tray MP210
Remove foreign objects from Rear Tray When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the Rear Tray.
Note : After confirming that the scanning unit support < 1 > is fixed into position, release your hands.
  1. Close the scanning unit (printer cover).
    Caution: Be careful not to pinch fingers when closing the cover.
  2. Power the printer on and confirm that the printer operates normally.
And
Clean The Paper Feed Rollers (Windows) Instructions how to clean the paper feed rollers. If the paper feed rollers become dirty, they may not be able to properly feed paper due to the feed roller's slippage.
If paper does not feed correctly, perform the following to clean the paper feed rollers:
  1. Open the Printers folder.
    - For Windows XP Home Edition : Click/Select 'Start,' 'Control Panel,' 'Printers and Other Hardware,' and 'Printers and Faxes.
    - For Windows XP Professional Edition : Click 'Start' and 'Printers and Faxes.'
    - For Windows Vista : Click 'Start,' 'Control Panel,' 'Hardware and Sound,' and 'Printers.'
    - For Windows 2000 : Click/Select 'Start,' and 'Settings,' then 'Printers.'
  2. Right-click the icon of the printer for paper feed roller cleaning, and select 'Properties' from the displayed list.
  3. Click the 'Maintenance' tab and click 'Roller Cleaning'.
  1. Remove all sheets of paper from the rear tray, then click 'OK'.
  2. Confirm the following message, and click 'OK'.
  1. Note: Clicking 'OK' will activate the paper feed rollers 30 times. This activation will take about 90 seconds. Do not perform other operations until this operation has finished.
6efb7a7.jpg After the continuous paper feeding operations in step 5 have finished, load three sheets of plain paper and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
  1. Click 'OK'.
Roller Cleaning is completed.
Cyber Kaka
Dec 08, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark e320 thumping on feed
The printer may report load paper when there is enough paper present in the feeder, however this could be due to number of reasons such as if there is something which is blocking the paper to flow through the feeder anything for example, some foreign martial like a pen or a pencil, please find few steps below to fix this issue.
1. Confirm that no foreign materials are inside the machine.
2. Confirm that usable paper is set.
3. Confirm that the paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets are not exciding the required number limit.
5. Adjust the paper feeder guide to the sheet size.
6. Disconnect the printer power cord as well as the printer cable form the printer.
7. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridge and check carefully if there is any small piece of paper which is stuck inside, if so carefully remove it.
8. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
9. Try to rotate the wheel inside the feeder if you can reach it, to ensue that it is free enough to pull the paper.
10. Try printing with having only one sheet in the feeder and check if it does work.
Should you require any further assistance regarding the printer or even any other compute related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 31, 2008 | Lexmark E320 Laser Printer
Paper loading
The issue you have posted regarding your printer which is un able to load the paper could be due to number of reasons like if there is any foreign material for example pen, pencil or any other obstacle which is blocking the paper to feed through the printer feeder then the printer will not be able to load the paper. However I would appreciate if you try the steps below in order to fix the issue.
4. Confirm that recommended paper is used, and the number of sheets set does not exceed the required limit.
5. Disconnect the printer power cord as well as the printer cable form the printer.
6. Turn the printer upside down and shake the printer in order to remove any obstacle which is stuck inside the printer causing the paper jam error.
Open the printer cover and remove the cartridges and check carefully if there is any small piece of paper which is stuck inside, if so remove it carefully.
7. Disconnect the printer power cord and press and hold the power button on the printer for about 15 to 20 seconds( this will release the flee power) and reconnect the printer and check.
8. Check and set the paper guide in the feeder to the paper size.
9. Try loading a single sheet and check if it is printing.
10. Try different type of paper.
11. try to rotate the roller inside the feeder which pulls the paper manually if possible to ensure that it is not jammed
Should you require any further assistance regarding the printer or even for any other computer related issue please feel free to contact me I will be more than glad to assist you.
Regards
Malik Khan
Jan 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
699 people viewed this question
David Payne
David Payne
