Question about Clarion XMD3
ERROR 6 CD WAS STUCK IN UNIT WHICH I HAVE NOW MANUALLY REMOVED. I NOW HAVE AN ERROR 6. UNIT WILL NOT ACCEPT CDS. EASY FIX OR TRASH THE UNIT?
  • COENMRCLEAN Jul 24, 2008
    POWER DISCONNECT DOES NOT FIX PROBLEM
    CD'S WILL NOT PHYSICALLY LOAD
    Master:
  • 382 Answers
You can clean the lens with rubbing alcohol or one of the lens cleaner discs or u can try spraying compressed air into it.. If that doesn't work, I would guess the pickup is bad... At which point you would be better off just buying a new CD mech...But if you can open it then try to unhook and then reattached the cd changer cable...HOpe this helps you....Thank you....
Regards!!!...
Posted on Jul 24, 2008
  • 4,234 Answers
Please clarify what you mean by "will not accept CDs". If the CDs won't physically load, the loading mechanism might be out of timing sequence or the loading belt may be slipping and not allowing thte load cycle to complete. If the CDs load properly, but are not being read, then look at the lens and try cleaning it using a cotton swab and alcohol.
Keep us posted.
Dan
  • 2,326 Answers
According to the user's guide if you get that error it means that there could be a CD inside upside down but in this case it could be that the lens did not went back to its default position. The default position of the lens assembly should be close to the motor that makes the CD to rotate.
  • Clarion Master
  • 19,396 Answers
Try unplugging power cord for two minutes, see if it clears
My 2000 SL500 6 CD cartridge will not eject The player works fine but I want to put in 6 new CDs and cannot get the cartridge ejected
There probably is a CD hung up between the magazine and the player mechanism. There is no easy fix. You will have to remove and disassemble the unit to get access inside. Once everything is back in place, apply power and try to eject the magazine. Otherwise, you may get the unit reinstalled only to find the magazine is still stuck.
Mar 27, 2017 | Mercedes-Benz S-Class Cars & Trucks
05 Chrysler DVD lights flash sequentsially,unit whirs, stuck disc(s)? Won't eject whatever.
IF YOU HANDY IT IS AN EASY FIX, I DID FIX MY. LOOKS LIKE YOU OR SOME FORCED A DISK IN TO THE CD HOLDERS.
1- I DID TAKE OUT THE CD CHANGER FROM THE CAR,
2-OPEN THE TOP CASING OF THE CD CHANGER,NOW YOU CAN SEE THE CDS AND THE HOLDERS WHICH SAPARATES THE CDS,IT IS VERY LIGHT TIN OR ALLUMINIUM PLATES, USSUALLY ONE OF THEM IS BENT THAT IS THE PROBLEM STRAITEN AND PUT IT BACK. FIX YA AND SAVE 500 BUCKS.
Jun 01, 2014 | 2005 Chrysler Pacifica
CDs are stuck in the 6 CD exchanger - I keep
hold the reset button for 20 secons the it should be fine
Dec 23, 2009 | Nakamichi CD-35z CD Changer
How do i get my lexus is300 cds out?
the only way to get them out is to remove the unit from the car and disassemble it. if you replace the unit it will go to an exchange company and if you request it they will send your cd's back.
Sep 21, 2009 | 2004 Lexus IS 300
6-disc Cd changer Mechanical Error
I talked to a dealer, all they could tell me is they have to send it to honda to fix it... a good 250$ for software fix...plus dealer will charge 50$ for each time they take the player out and in...
Jul 27, 2009 | 2005 Honda Accord
How to remove radio faceplate on 2003 Toyota Camry?
U don't have to remove anything, just get a laser lens cleaning disk from any store that carries music CD's Walmart has them for about $6
Mar 22, 2009 | 2003 Toyota Camry
Monsoon Radio CD CHANGER ERROR
CHANGEUR CD ERROR . g6 2006
Jan 14, 2009 | 2003 Hyundai Santa Fe
Emerson MS9700 CD Shelf System - CD Tray won't open
Ironically, I am here searching for information about this kind of problem too, except I don't have cd's stuck in the unit. This one has done the no power on trick as well as some other pretty stupid stuff. I know this is an old post so if you haven't got it working yet or gotten the cd's out, the only way I know of to do this would be to remove the screws on the outside of the unit and remove the case. Once you do this you can get the cd's out, then.......... TRASH THE THING!
Aug 26, 2007 | Emerson MS9700 CD Shelf System
You have to unscrew the whole thing and take the whole metal covering off and then the inner tray will be displayed and then you can just take the CDs out and then screw the cover back on. Happened to me, and that worked :]
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Clarion XMD3 Logo
168 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
