Question about Volfenhag 1000 WATT AMP 4 CH AMPLIFIER 1000W Car Audio Amplifier
Amp not working
My amp is getting power to it but it will not come on the power light dosent come on and no sound come from my 2 10's
If your light is not coming on then you probably dont have power to it. check all your connections and make sure it is all hooked up right. check the remote with in the back of the deck.
Posted on Jul 25, 2008
Hi i have a plasma lcd samsung tv model:PS-42C91HDX it has power going into the tv as the blue light under the front panel below the power on button is on when i push the on button nothing happens. no
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 07, 2015 | Samsung Televison & Video
Nad c355bee
Check to see if it works with headphones. If it doesn't then you might have a main power amp failure.
Aug 06, 2013 | Audio Players & Recorders
Why is the red light that says protect on? my amp turns on but it dosent work, i have a sup hooked up & it dosent work. the red light that says protect is on.
first thing check all ground and power wires and make sure ur rca wire make sure it isnt cut in anyway. after that unplug ur sub and unplug the negative wire from ur amp, while its out check the fuses on the amp if all is well put all fuses back if not get new. then plug the negative wire back in if protect goes off check for heat and if no heat inspect the wires from speaker out put all the way to the sub, look for any wire touching another this is were most problems are even the smallest wire can trip a protect. if u still cant find the problem. an amplifier specialist is in order.if its trashed go on ebay and buy a powerbass there goin cheap right now. hope i could help
Oct 12, 2010 | Lanzar VIBE266 Car Audio Amplifier
My jl 500.1 amp dosent play anything.
you have your sub wired incorrectly. your amp shouldn't get hot unless you're settings are too high or your'e sending too small of an ohm load to the amp. this would cause it to heat up and will fry your amp.
May 30, 2010 | Jl Audio 500/1 Car Audio Amplifier
My amp is not working
For the visonik, you should check your speakers. You can use a D-cell battery. Remove the speaker wires from the amp and connect each speaker across the battery (for no longer than a few seconds). The speaker should pop each time the wires are touched to the battery. If they don't, the speaker is defective (assuming the battery isn't dead).
If the speakers are OK, you need to confirm that you have a good signal feeding the amp. You can use the RCA cables from another working amp in the vehicle. Do this with the amp that had the power light lit.
If you have signal going to the amp and the speakers are OK, the only two things left are the power supply feeding the amp (from the battery) and the amp. If you have B+ and remote voltage AND a good ground, the amp is defective.
For the pyramid, the amplifier probably has shorted output transistors. The amplifier will have to be repaired.
Nov 16, 2007 | Visonik V117SX Car Audio Amplifier
Blitz BZA2000D protection error
Either you will have to see a repair tech or get your money back. Sorry about the bad news. If you have a blown output (which is what you probably have) then it is more of a problem than a regular consumer should attempt to repair. Sorry.
Apr 02, 2007 | Blitz BZA2000D Car Audio Amplifier
Amp is on but nothing coming out of Sub
If one amp works inthe same place same wiring same hookup, and the other one dosent, It got to be a bad amp or the way its being hooked up. Make sure the standby is hooked up properly. Get the wiring diagram for instalation for both amps and look at them side by side. If the dead amp is supose to work then Im sure by comparing hookup your gonna say "AAAWWWWW I See Now!!" Good Luck
Jun 23, 2006 | Legacy 2 CH 1800W RED AMP Car Audio...
NEW AMPLIFIER WILL NOT LIGHT UP OR POWER UP
It sounds like your saying that you have two identical amp, that both are on the same power wires and remote wires and sam grounds? Well if thats the case then you did ok as One amp sounds like its blown. First tghing is check the main fuse. If its good and the unit still dosent resond then the power supply in the amp is blown as theres a switching supply that increases the 12 volts to get power to drive the Mosfet output devices. Was it ever working?? yes then the amp needs service. Do you know how to work on solid state elctronics down to componet level?? No?? Ok contact these folks at the addy im posting for you or take the amp to your local servicer. Good Luck. AudioSupport@VisonikCarAudio.com
May 07, 2006 | Visonik VB212PKG Car Audio Amplifier
Volfenhag 1000 WATT AMP 4 CH AMPLIFIER 1000W Car Audio Amplifier Logo
119 people viewed this question
Top Volfenhag Car Audio & Video Experts
Robert Rankin
hoyzee1
Are you a Volfenhag Car Audio and Video Expert? Answer questions, earn points and help others
