Question about Lexmark Wheelwriter 1000 Typewriter
Broken Button My return button will not work. Therefor when I get to the end of a line and cannot start a new simply by pressing the button.
    New Friend:
  • 120 Answers
The trip spring under the return keytop needs replacement. Lawrence
Posted on Jul 28, 2008
2011 ford escape limited the remote start stopped workng
Remote starter in valet mode Symptoms: Lock and Unlock buttons work as normal, but pressing Start does not produce any response from the vehicle.
Causes: Someone accidentally pressed the combination of buttons to put the car into valet mode, usually when the remote is in a purse or pocket. Also, many remote car starters will revert to valet mode when the vehicle is disconnected for service.
Hood Pin Has Broken or Failed Symptoms: Pressing Start results in several flashes of the parking lights but no start. If equipped, Lock and Unlock still function.
Cause: In most cases, the under-hood pin switch is broken or corroded.
Remote Control Loses Programming Symptoms: Pressing any button on the remote results in no response from vehicle.
Cause: It is rare, but does happen - in most cases, this is caused by a dead battery in the vehicle or the battery having been disconnected when being serviced.
Remote starters usually have some type of non-volatile memory to retain things like programming features and remote control codes. Like any "computer" device, sometimes they lose memory. When this happens, simply call the store that installed it for you. In some cases, they may be able to tell you how to reprogram it over the phone. Other times, you will have to return to the store for a technician to program it. In any case, this is rare with higher-end remote starters.
Remote is in Second-car Mode Symptoms: Pressing any button on the remote results in no response from vehicle.
Causes: A combination of buttons were accidentally pressed, which put the remote in second-car mode.
Again, this is very rare, but happens from time to time. Many remote car starter remote controls have the ability to start two vehicles. If the remote is accidentally placed into second-car mode, it will not start or operate vehicle #1.
Simply read your owner's manual or call your installer for directions on how to revert the remote back to car #1.
Dec 08, 2016 | 2011 Ford Escape
I pushed the button down to start the jets and it got stuck all the way down and won't come up
When an air button does not come up after being pressed down it is a classic sign that the button needs to be changed.This happens when one of a couple things happen:
  1. The bellows in the air button have broken and therefor cannot push the button back up.
  2. There is calcium built up on the inside of the button
  3. You can clean up the calcium deposits with emery cloth
Rod
US Parts Center
Apr 03, 2013 | American Standard 1748.102 Colony 5.5' x...
Broken power button
The power button has 2 wires conected to it. All you have to do is to take these wires and simply join the two wiresfor a second or two, until the computer starts. after that you letthem go so they do not touch because it will turn your computer off, like when you keep the power button pressed continuasly
Dec 05, 2012 | Computers & Internet
Saying test on my wt965 washer
There are few methods, depends on the age of the appliance.
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Simply press the Cancel button and the appliance returns to default.
Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
or
Switch off at mains, press and hold On/Off & Start/Cancel buttons, switch mains back on, keep holding down buttons until Doff appears in display.
Nov 02, 2012 | Hotpoint Washing Machines
Saying test on the display unit
d OFF appears.
or
Nov 02, 2012 | Hotpoint Ultima WF860 Front Load Washer
Have two lg tvs which work off same remote is it possible to reprogramme one
*If you start this procedure and at any time do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again.
  • Press and hold the desired mode button (about three seconds) until all mode keys light up, then release.
  • Use the number pad buttons to enter the three-digit number corresponding to the equipment (codes are available at http://tech.dishnetwork.com/departmental_content/TechPortal/content/tech/remotes/techremoezcode.shtml). The light will blink off after each digit is entered and then return to a steady light.
  • Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
  • To verify the code works, try several functions for that equipment.
Parts For BMW
Jun 12, 2012 | LG Televison & Video
Instructions for brother p touch 1000
Instructions1 Turn on the device by pressing the power button. If this is the first time that the machine is being turned on, select a language with the arrow buttons and press the return button. Select a unit with the arrow buttons and press return. Set the date and time with the keypad and the return button.
2 Type in the text for the label using the keypad. Correct mistakes by pressing the "Backspace" key and retyping. Press the return button when the text is ready.
3 Select the appropriate styles and features for the label. The device will provide you with a wide range of choices for the size, style and width of the text. Simply select which feature you would like with the arrow buttons and press the return key to move on to the next option.
4 Print the label by pushing the "Print" button. Make sure there is paper in the device. It may be necessary to press the "Feed" button to align the label within the device. Print as many labels as necessary. To erase the text, simply press the backspace button until the text is gone.
5
Turn off the device by pressing the power button.
Mercedes Custom Parts
Jun 06, 2012 | Brother Office Equipment & Supplies
I am on Dish Network...how do I set my Dish remote to turn on/off my Sharp Aquos 52E77UN televisiona
  • Use the number pad buttons to enter the three-digit number corresponding to the equipment (026, 091, 105, 106, 107, 108, 128, 129). One of the three digit combinations will work. The light will blink off after each digit is entered and then return to a steady light.
Jul 08, 2011 | Sharp Televison & Video
Hotpoint washer will not start when you press
Try the following, may work:
  1. Press the Start/Cancel button together until all the console Led's illuminate
  2. Press both Start/Cancel and On/Off buttons together until 'd off' appears
  3. Default screen should return and you can select a new programme
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
Carriage return problem
The tab button may be stuck or the carriage release lever is stuck or a broken escapement.
Dec 24, 2008 | Smith Corona Wordsmith 100 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
