Question about OKI Office Equipment & Supplies
OKI B620 "SET DRUM/TONER CARTRIDGE" CAN'T ACCESS MENU OR PRINT ANYTHING
leroyal
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
LizBux820
SOURCE: Have an OKI Printing Solution
Found this at Fixyourownprinter.com
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Worked for me when I had the same error. Hope it helps.
Posted on May 26, 2009
Ryan5443
  • 336 Answers
SOURCE: my printer says set drum/toner cartridge. How?
Okay, I have a web address that has instructions for replacing the drum, just follow the instructions, but just put the same drum back in, and turn the printer back on. That should Help. If you have any other problems please ask them.
http://my.okidata.com/tech-b6200-b6300.nsf/da3f02601112ab7a85256ade00596069/fb3af0dd851c2c8085256eeb0049d869?OpenDocument
Thanks You,
Ryan Frame
Creative energy Associates Technical Center
Posted on Jul 28, 2009
  • 97 Answers
SOURCE: OKI B6300 DRUM/TONER
try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Posted on Mar 29, 2010
pineworks
  • 4041 Answers
SOURCE: My Oki B2200 is repeatedly showing Toner is empty.
Hi there
I not know your printer but I can say this that after refilling it your chip will still thing it emty so some where on the printer Menu there is a way to reset the it back to 0 so it starts like new again.
Sorry cant be any more use to you than this, try looking up the net or the manual to how to reset.
All the best : Pineworks
Posted on May 10, 2010
Oki b6300 set drum toner cartridge, I replace the toner twice put it still give this message, and the new toner if i put it in anthor printer this message apper eventhough the toner is new and I tried two...
Press the Menu button
GO to "Admin Menu"
Select "System Settings"
Select "Drum/Toner Life"
Choose "Continue Print"
(press Feed/Select - which places a * next to the field)
press the Menu button again to exit
Feb 24, 2014 | Office Equipment & Supplies
Trouble with Oki B6300 drum/toner cartridge replacment. Can't get back into the menu to reset the printer.
Try removing and then reinstalling. If this happens since you changed the drum and toner, then the issue would be with the defective replacement. Way to test is to reinsert the old drum and toner and if this does not happen, then you know the issue is with the new supplies
Jun 12, 2012 | OKI B6300 Laser Printer
The copies look faded out as if a new toner is needed, but I just changed the image drum and the toner cartridge
It could be that the print density setting is set too low. Adjust to higher density printing.
If the ink of the toner is not well distributed, remove the cartridge toner from the printer. Shaking it to redistribute toner more evenly will help..
Reset the printer
On the printer press the menu button until you reach MAINT.
Then press the item + button until you reach DRUM CT RESET. Then press select.
That will fix it.
Thank you for using Fixya
Alp
Sep 19, 2010 | OKI B4600 Printer
try this:
6.Press Ready
Jul 28, 2009 | OKI B6300 Laser Printer
My printer says set drum/toner cartridge. How?
RESET OKIDATA TONER DRUM
8. Restart printer.
Jul 28, 2009 | OKI B6200 Laser Printer
Replaced K toner and machine is telling me there is no toner in it.
There are sensors along the inside right wall that tell the unit if there is a K cartridge inserted. Usually what happens is that due to a toner spill, the sensor LED is covered with toner and or is bad . Hence it does not see the K cartridge. This happens mostly with the black or K cartridge. Get some compressed air and lightly shoot some into the hole that corresponds to the K cardtridge. Only in the hole, do not spray the air anywhere else in the printer.
If this does not clear it up, you would need to replaced the sensor board which is held in with 12 springs!
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | OKI C3200n Led Printer
OKI C5400 & Vista
Assuming that you are using the same paper and have not changed any of the consumables you should do the following:
1. Clean LED head with lens cleaner or soft tissue.
  1. Remove the toner cartridge and give it a few shakes then reinstall it.
  2. The Toner Could be low so Change toner cartridge.
4. Make sure that the paper is not damp as this will cause fading and poor quality printing and images.
  1. The image drum may have been light contaminated so remove it from the printer and store it in a totally dark place for several hours then reinstall it.
  2. If the image drum is dirty then wipe it very gently with soft tissues, being careful not to scratch it.
  3. Open the top cover and check to be sure that each toner cartridge is fully seated and that each toner cartridge lock lever is pushed all the way back.
  4. Press the top cover release latch and open, then close, the cover.
  5. Check MEDIA MENUTRAY1 MEDIA TYPE and set as required. Do the same for TRAY2 and MPT.
  6. Check MEDIA MENUTRAY1 MEDIA WEIGHT and set as required. Do the same for TRAY2 and MPT.
  7. Possibly set the value of media weight in the menu to the next heaviest one.
  8. Check PRINT MENURESOLUTION setting and set to 600 x 1200DPI
  9. Check PRINT MENUTONER SAVE MODE and make sure this is OFF
  10. Check PRINT MENU – MONO PRINT SPEED and make sure this is set to MIXED SPEED
Aug 12, 2008 | OKI C5400 Laser Printer
OKI c5400
  11. Check the COLOUR MENU – DENSITY CONTROL and set this to AUTO
  12. Check the COLOUR MENU – AUTO DENSITY and set this to EXECUTE
  13. Check the COLOUR MENUCMY 100% DENSITY is set to ENABLE if you want a glossier black finish.
Feb 17, 2008 | OKI C5400 Laser Printer
OKI c5100 Printing GREY instead of BLACK.
Not able to print a status page. Tried holding down menu 5 sec and no output. I searched the menu and am not able to find how to print status page. I did print out a demo page and the black is great but when i print out text (like the entire menu map) the black is grey. Let me know if there is anything else I can do.
Jan 12, 2008 | OKI C5100n Laser Printer
78 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
