Cell Phones Logo
Posted on Feb 15, 2011
Unlock codes for LG prime - LG Cell Phones
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
85
Points
I need codes for my lg lw310
1helpful
Unlock my lg prime gs 390
What's your Network provider?
There are many ways to get the code like www.MobileUnlockSolutions.com here specify your Network provider,Country and IMEI...After they send the unlock code through your E-mail..Then you can use this code to unlock your LG Prime GS 390 to swap any other GSM networks...
My lg prime is locked and i forgt the code
You can buy the unlock code from service provider,You cannot get that means you can get the unlock code from online site and unlock it.
Nov 21, 2011 • Cell Phones
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Hello good people, I need unlock code for LG prime GS390
1234 or 0000 but if simlock then you will need to take it to a nearby mobile engineer to remove simlock
How do i unlock a lg prime so i can use it threw another cell phone provider
It is possible for your phone to be unlocked permanently from other networks worldwide. just use the codes that will be supplied to you by an LG UNLOCK CODE provider. You may have to enter your phone brand and model, IMEI numbers which can be retrieved by pressing *#06# on your phone keypad and the network and country the phone was purchased from. Once all requirements are met, the LG PRIME unlock code will be sent to you right away.
2helpful
3answers
Free unlock code for lg prime
you can get the unlock codes for your LG model mobile, through this site http://www.theunlockarena.com/lg/rs13wp8/
It has the best instructions and methods for unlocking mobile phones at very low cost itself...........
6helpful
3answers
I need the unlock code for lg prime.
You can usually get a free unlock code for your phone by calling up your phone carrier, otherwise, you can learn some other ways to get an unlock code from this LG Prime Unlock Guide.
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
