Question about Xerox WorkCentre 4118 Network Kit - 1 x 10/100Base-TX - 100Mbps (0095205226850) Print Server
Xerox wc 4118 scan option
i need to scan some documents using the xerox machine, how can i do that remotely?
help!!!!
    Scholar:
  • 92 Answers
You will not be able to send the scan request if you are not inloco.
Posted on Aug 27, 2010
  • 1 more comment
  • Rui Sep 08, 2010
    I have forgotten to let you know that you also have possibility to use USB connection and this will allow you to pull images from the scanner using a twain driver. Nevertheless this goes away from the ethernet configuration you mentioned on your problem subject.
    Here is where you can get the twain driver from:http://www.support.xerox.com/go/results....
  • Rui Sep 08, 2010
  • Rui Sep 08, 2010
    .support.xerox.com/go/results.asp?Xtype=download
Changed drum on workcentre 4118, and still says change drum
TURN ON MACHINE. PRESS MACHINE STATUS; PRESS ADMINISTRATIONS TOLS;PRESS ARROW HIGHT UNTIL APPEAR M ANUTENCE; PRESS OK; PRESS ARROW HIGHT UNTIL APPEAR "NEW DRUM". PRESS YES.
PRESS OK. THATS IT.
TURN OFF THE MACHINE; WAIT FOR 30 SECONDS; TURN ON.
Feb 12, 2013 | Xerox WorkCentre 4118 Network Kit...
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
Error code 024-747 is given when trying to print a specific Word 2010 document although any other Word 2010 document seems to print without any problems. Can you tell me what this error message means and...
In my case was like when i tried to print MS Word or Excel document (Xerox WC 5020 & WC 7120) i had to set "Original document size" in Paper Type option as same as "Output document size" in Printing preferences - it should help.
Jul 22, 2011 | Xerox DocuPrint C4350 Laser Printer
Workcentre Pro 245 shows an "Internal Power Supply Failure". We just got the machine and it tested OK. We moved it carefully and tested it again OK. But an hour later, it showed this error...
There are 4 solutions to try and they don't fit in their entirety so I included links to each one. Please be sure to read the instructions entirely AND ensure you need to perform each one.
1. Power machine on and off http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4322)
2. Clean the Charge Scorotron and the Transfer Corotron: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(4186)
3. Perform a Software Reset at the Printer: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(5315)
4. Replace the Xerographic Module and Transfer Unit: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=269,E=0000000002703128583,K=4118,Sxi=8,Solution=obj(3362)
If none of those fail to resolve it call for service.
Hope it helps!
Mar 08, 2011 | Xerox Office Equipment & Supplies
Hi, I just purchased a Xerox Work Centre 4118 for my office. I have Windows 7 Professional and am unable to Print via wireless. I receive a message that the Printer is offline. Would you be able to...
http://www.support.xerox.com/support/workcentre-4118/downloads/enus.html
The above links to the drivers page, but unfortunately, I do not see specific Windows 7 drivers for this printer. This means that older XP or the latest drivers from the year 2008 are used in emulation mode, maybe, for Windows 7.
Since this is not a 'new' printer, I gather, it will not guaranteed to work with Windows 7. However, I would try the link above for various drivers which may or may not work on this printer.
The fact that the Printer is shown to be offline, is a bad sign.
I read that the printer in question has the following connectivity:
Connectivity
But, that it doesn't support WiFi.
USB, Parallel, optional 10/100 BaseT Ethernet.
Jan 19, 2011 | Xerox WorkCentre 4118 Network Kit...
Paper size Mismatch on Xerox workcentre 4118
HI wat you can do is Most likely the tray setting has changed, Here is what to check. Press the [ Machine Status] button on the Control Panel..
Jan 10, 2011 | Xerox WorkCentre 4118 Network Kit...
Xerox 4118
That isnt unusual. The 8000 pages is for a page with 5 percent coverage area, or a rather short letter.
the 3600 to 4000 pages is not out of the ordinary for that machine, Although the xerox brand may work better, although not more copies, if you run pages with more than 5 percent of the page printed, that is about right.
Also there is no chip on a 4118 cartridge. The toner is monitored by a sensor and window in the middle of the cartridge. It shines light through the cartridge, and when the cartridge is empty the light actuates a light activated sensor.
it is not an efficient machine.
Dec 15, 2009 | Xerox WorkCentre M15i Laser Printer
Drivers installation
Here is the web page with your Xerox printer drivers and software:
http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=WC4118&Xlang=en_US&Xcntry=USA
Regards,
Graemevm
Apr 28, 2009 | Xerox WorkCentre 4118 Network Kit...
Xerox WorkCentre 4118 Network Kit - 1 x 10/100Base-TX - 100Mbps (0095205226850) Print Server Logo
1,253 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
