Bush record player (1963) worked perfectly but today the turntable
Started squeaking and now it won't move at all. Is there a way to fix it?
  • 163 Answers
Check for any obstructions underneath the platter. Should be a removable black static mat and then the platter is visable. Check condition of the belt and replace if necessary. With the age of the unit you might have to order a belt by size rather than make/model. Check www.stylusplus.co.uk for parts. MM85
Posted on Jul 24, 2008
Crosley Cruiser turntable vibration noise
How to Identify Damage in Your Record Player ' eBay
www.ebay.com > ... > Record Players/Home Turntables
They produce audible sound by reproducing sound vibrations from tiny grooves etched on the surface of vinyl records. Record players have three primary ...
Crosley Cruiser Turntable Review - YouTube
? 2:26
https://www.youtube.com/watch?v=w5KVANeimVU
Dec 8, 2013 - Uploaded by DTM
This is a review of the Crosley Cruiser turntable. ... cartridges (the mechanism that converts the vibrations of ...
Just getting into vinyl. Is there any way to improve a Cros
Dec 14, 2015 | Crosley CR8005A-TU Cruiser 3 Speed...
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
I have a Spirit of St. Louis turntable that won't turn.
This model of turntable automatically stops when the needle reaches the center(the end) of the record. The motor should turn back on if you move the arm to the far right of the player, past its resting spot.
May 02, 2013 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Replace the needle on Bush RPA1
Take the whole unit, open the window, toss the unit out the window and replace with something decent as this TT is a pile of junk and is probably ruining your records. Problem solved.
Nov 28, 2012 | Bush RPA 1 Turntable
ION Profile LP Vinyl-to-MP3 Turntable, tone arm won't drop
I've got the same problem. When you put therecord on, spin it from the centre, and it will release the mechanism inside,this is what I do, and it works fine. I think the problem is that there are twoplates under the turntable, and there was grease between them, after a few goesthe grease disappears, causing the problem.
May 22, 2012 | Audio Players & Recorders
Can't get the record player to work on a detrola
Thank you for the solution of moving the arm to the right and wait for the click, now my turntable works and Keely Smith is playing and sounding great!
Apr 22, 2012 | Crosley Audio Players & Recorders
Turntable won't stop spining
If it is a turnatable that starts spining when the arm is moved to the record, then more than likely the start/stop switch inside the turnable is broken and is fixed in the on position. Or the leaver mechanism has become detached from the arm when the record was playing and left the other part pressing on the same switch that turns the motor on or off.
Removing the bottom of the turntable should should show the trouble.
Apr 03, 2012 | Philips WMM142211 Turntable
I have a bush turntable cd radio usb set. no problems recording my vinals to the USB however the sound is "tinny" with no bass whatsoever.\r\n Is there a fix for this? was thinking it might be...
Your vinyl records probably were recorded with RIAA compensation (the jacket will indicate). Your USB connection may be flat (without compensation).
Dec 16, 2017 | Bush Audio Players & Recorders
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
Everything works on my record player but my turntable doesnt spin
This happened to me tonight. I had the same problem, to activate the player on you need to move it to the right until you hear a click. If you don't do it it won't start. Even if all the power is on. This should fix everything!
Sep 28, 2009 | Crosley 0187SST Turntable
63 people viewed this question
 Grubhead
Grubhead
