Question about Sony KV-32FS13 TV
Sony kv-32fs13 4 blink code
Already had a tech come by and estimate cost.
said it was some like deflection fault or power error.
$350.00! is this right?
  • Anonymous Aug 06, 2008
    tv turned on no pic only vertical output but audio ok then off then blink 4 times
  • 2,296 Answers
The tech is wright about the deflection board having a fault. This failure is found in the vertical deflection circuitry.
The quote is the one that seems to be a bit high, instead of getting this TV fix; I would save that money to buy another TV.
Good Luck.
Posted on Jul 24, 2008
Sony xbr KV-34xbr910
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 06, 2014 | Televison & Video
KV-34hs420 LED Blinks 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Apr 28, 2012 | Sony KV-36XBR400 36" TV
Sony Trinitron KV34HS420-standby timer does 7 blinks when powered on
7 blinks on the model above is an error code for faulty horizontal deflection circuitry. The B+ gone to excessive current that is detected by IC5007.
Fixing this kind of symptoms needs technical skills on electronics to isolate the faulty parts. Let me know if you're handy, have necessary tools and test instrument and I will help you diagnose where the fault came from to resolve the issue.
If you feel you can't do it yourself, I would advice you to ask for an assistance of a qualified technician. Ask for an estimate first to your local repair shop to have an idea how much money you are going to spend sending the unit in.
Feel free to ask question of you need further assistance.
Have a nice day!
Jdvillanueva
Nov 25, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
7 blinks
7 blinks is an error code for "Horizontal deflection malfunction". This circuitry is the one generating high voltage for the picture tube and other voltages through the flyback transformer. Sad to say that this is not a DIY because safety precaution is a must working on this section to avoid further damaged and electric shock.
The flyback transformer, horizontal output transistor, fusible resistor, jungle IC must be check by a qualified TV technician to isolate where the fault came from.
I would advice you to ask for an actual estimate from your local service center for the service fee plus parts let say flyback transformer to determine how much money you are going to spend sending the unit in.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 26, 2011 | Sony FD Trinitron WEGA KV-32HS510 32" TV
My Sony Trinitron CRT TV is not powering up. It comes on and goes off in a few seconds. The standby LED is blinking 4 times. I read somewhere that this could be an issue with Vertical deflection/power...
I had one of these in the 36" version blinking 4 times but it was not the vertical. It was the color amp ic at the crt board that was shorted and an open resistor. The repair for this, if my diagnosis is correct, should not be more than $100. Ask for an estimate though to be on the safe side. Thanks for using fixya.
Mar 11, 2010 | Sony KV-27V42 27" TV
KV-32HS500 WON'T TURN ON standby light flashes 7 and sometimes 6 times and has flashed 4 times also.
These are sony error codes while in protection mode. The 7 blinks means high voltage exceeded 33k volts ,caused by either horizontal or power supply circuits.
The 6 blinks code is for no horizontal deflection, and the 4 blinks code is for no vertical deflection.
So the one thing they all have in common is the power supply that will need to be repaired before you can use the set again.
Hope this help. Good luck
Please do not rate this answer(unless it helps) as it is only a suggestion/information.
Dec 02, 2009 | Televison & Video
Standby lighy blinks tv won't turn on
error code 4 is vertical deflecton failure . replace the vertical deflection ic. and the electrolytic capacitors in the vertical circuit. Or if you are lucky just resolder the vetical IC and resolder th horizontal section too.
Sep 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
KD34XBR960- NO PICTURE blinks 7 times. Thanks
Horizontal Deflection
Stopped
7 times 7:0 or 7:1 • No picture
Horizontal Defl ection Stopped
Occurs when either:
1) a +B overcurrent is detected (IC5007), or
2) overheating is detected (Thermistor TH5002).
IF YOU WANT TO DOWN LOAD A FREE SERVICE MANUAL OR TECH MANUAL FOR YOUR T.V. HERE IS A SIGHT THATS TOTALY FREE
http://www.schematicsforfree.com/archive/dir/Sony/Video
Apr 13, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Vega Service Codes
KV-32HS510 and KV-27HS420, seven times blink error code shows problem in Horizontal deflection circuit.
There are many possibilities like dry solder joints, weak capacitors, Horizontal transistor short or flyback transformer fried etc.
If you have little experience of TV repair and good solder skills and have necessary tools to test / check defective parts, then you can make it. you also need to have related service manual to see board location, schematics and part numbers.
Dec 12, 2008 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony KV-32FS13 TV Logo
171 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
