Question about Sony Playstation 3 (PS3) Console
Message that game will not play at current video setting
Game will not play; setting will not change from 480i; TV is standard, connected through composit cables. Game will play on 22" Samsung HD computer monitor connected through HDMI/DVI cables, but of course no audio. How can I make game play on standard def TV?
  • 344 Answers
Hello.
You just need to restore the defaults for the video. Here is how to do this.
1. Reset the Video Output Settings. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings. Once you turn it back on, it should work fine.
I hope this helps!! Good luck!!
Posted on Jul 28, 2008
The setup reads on a 480i when it should be in 1080i. How do I get the system from the 480 to 1080?
our TV has a 1080p display screen and it does not change. What changes is your input signal. When you see a little message on screen saying "480i" (or anything else), it's telling you the resolution of whatever you have connected to the TV. In this case, it's most likely a standard-def TV channel.
If you *are* using a cable or satellite receiver, you need to get into its menu and set its output resolution to 1080i (which is the maximum for TV channels). Also, it needs to be an HD receiver, if it isn't already.
You only get true 1080p from a Blu-ray player or from certain game consoles.
Apr 04, 2016 | Televison & Video
Where to start.....alright. I currently have a softmodded Wii console, and I recently bought third party component cables for it. The cables work fine under Standard TV resolution (480i), but when I change...
From the Wii Channels menu, click the "Wii" button on the lower left of the screen. From there choose: Wii Settings > Screen > TV Resolution. In this menu, click on the "EDTV or HDTV (480p)" option and then click "confirm".
Aug 07, 2013 | Nintendo Wii Console
I bought my ps3 from USA and got some game disc from Australia (region 4) it doesn't work,a message pops up when i press start (cannot play on current video settings, but i was told that ps3 games are...
PS3 games are region locked to the Blu-Ray standards where the game was bought. I doubt that Sony will change this, because they are one of the major backers behind the region standards. Your best bet to play the game is to softmod your PS3 (risky) or to hardmod it with a modchip (vaguely illegal, warranty voiding, ect.)
Mar 16, 2011 | Sony Playstation 3 (PS3) Console
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
How to set up to using hdmi
#1 your tv would need to be hdmi compatable (have the appropriate plug on the back where all the inputs are located). For example I have a 60" Lcd HDTV and an xbox360 I attached the standard a/v (audio/video) red,white,yellow wires to tv and turned on the game console went into system settings and turned on the hd setting to 1080i for hi def resolution. Another alternative would be to connect console to your dvd player (most new dvd players will up convert signal from 480i or 720i to 1080i hd) and attach your hdmi cable between the dvd player and the tv to support the hd interface. Something I highly recommend is the jvc th c50 home theater surround sound when I play call of duty it has enough to knock stuff of our bookshelves and ******** the neighbors. Happy gaming
Dec 09, 2010 | Video Game Consoles & Games
Some Virtual Console games don't work!
When using component video cables and a HDTV: Go into the Wii's system settings, under Screen, change TV Resolution to HDTV (480p) instead of Standard TV (480i) and change to Widescreen (16:9) under Widescreen Settings.
This worked for me, good luck!
Nov 18, 2008 | Nintendo Wii Console
Wii VC games won't play on hdtv
I had the same Black Screen problem and I finally have a fix for it!
Sep 28, 2008 | Nintendo Wii Console
Some gmes won't play.
Ok. Do you have a NTSC system?
Some PAL games will only run on standard and some will only run in HD and some will run on both if the PS3 is NTSC. The PAL games output at (576i/p) while the NTSC outputs at (480i/p). So honestly, I think that is your problem. You have a NTSC system and PAL games. If you do not have a HDTV then you will need to exchange those games for the NTSC version. Sorry for the bad news. It's not Sony's fault, it's how the game developers coded the games.
I hope this helps. Good luck to you.
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Some games won't run on my PS3 40mb
Hello.
All games should run regardless of the settings. Are they PS3 games or games from the PS1 or PS2? That could also make a huge difference. The 40GB PS3 is not fully backwards compatible. Also, if they are PS3 games, try the reset default video settings. That might even work. Here is how to do that.
I hope this helps. Good luck!!
Jul 24, 2008 | Sony Playstation 3 (PS3) Console
Analog out of range
Are you playing the game from a computer or a video game system? 800 x 600 res is fine if it's a PC. If you have a video game system, then you have to go into the video game system's menu, ans select resolution of 480i - only on ps3 or xbox, however.
May 26, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
60 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
